BX 1.9GTi 4WD -90 -Project
Looks like I can't get rid of BX
So, while browsing web, i saw "Give away, BX 4WD"
I thought about it a few secs, and week later i went for it.
It needs some doing on bodywork, but other than that, it's in good shape, no major rust and engine works good!
It hasn't been on the road for past 10 years!
Rear axle bushes are totally broken, but i've ordered new ones.
2 of the injectors weren't working, so it didn't run when I got it, but now it has injectors from 2litre XM, runs Still need some more new gasoline..
I started to add some new parts for it and gave it a good wash, looks better already! Still need to replace passenger door..
Looks like my old grey GTi did when it has white Xantia steelies too
CCC BX Columnist
'89 16v P1
'93 ZX Volcane TD 3 Door
'98 Xantia Activa P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
'89 16v P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
. That avatar pic is real. It has 600x300x76 intercooler, turbo is from 850 T5 Volvo, should be good for 280hp. Now im waiting for PnP Vems and 663cc injectors from Dp-Engineering, im hoping for 250hp, if this original clutch can take that..mihaistan wrote:very nice man ! good luck with the new project !
question : where can i see your activa ? what did you change ? if the avatar pic is real ... i`m very curious !
Don't throw the old injectors away as they are probably not faulty, just gummed up!Jeth wrote:2 of the injectors weren't working, so it didn't run when I got it, but now it has injectors from 2litre XM
Getting them ultrasonically cleaned and serviced should make them as good as new. Tell the cleaning company that the car has been laid up and the dormant injectors need a "tap" on the metal body when on the machine to get it pulsing again.
- rayfenwick
Re: BX 1.9GTi 4WD -90 -Project
Excellent car! I'd love a 4x4 GTi... maybe one day
