Heater Tap/Control
kiwi
- x 4
Heater Tap/Control
The dreaded Heater Tap problem has struck! Well its been like it for a couple of years now where the sludge in the gate has built up so the tap can not be completly turned off!
Well thats what the dashboard dial says anyways! Thats the problem now an over enthusiastic driver/passenger (ie when the wife has had the car) has tried to turn the dial closer to the blue bit and you know whats happened to the dial behind.
So has anyone come up with a suitable solution to those dodgy dashboard dials?
I am still getting cool air so the tap problem is minor. Just now I cant turn the heat up. Coming into winter there I am sure you guys know what I mean.
1990 BX19 TZS Auto 06/11/1989
- BXpat
My 16v has got a piece of wire which hangs into the passenger footwell and pulling said wire shuts off the tap. I didn't do this, I don't recommend it but it works ( til I get round to lubricating the mechanism and cables properly) but then it's a left hand drive car so perhaps this wouldn't work for you strange blokes who sit on the right hand side!
Brian
Hi Kiwi,
Some time ago now, when I replaced all the dash lamps "bulbs", I removed all the cables from the heater to lubricate --- Bad move.
No mater how I tried, I could not re engage one cable, it was just too short, so this is what I did.
Used an old radio knob from my junk box, bent a 90 degree on the cable end, used epoxy to fix it together.
Then made up a simple bracket and screwed to the dash.
Still working fine todate..
Mike E (uk)
kiwi
- x 4
Looks like another modification to meMike E (uk) wrote:What's that unusual keypad for under a cover to the left of the door open indicator?
Mike
A scanner prehaps
I reckon its one of those credit card cloning machines, pop in a card & up comes the pin details
BX 16v Ph2 - XPO - x 103
I managed to literally bolt mine back together. The pin for the cam had failed, rather than the short black pin the knob sits on (ie the knob didn't fall off but would turn and turn).
A rather unusual failure mode i admit, but thought i would mention it as you've haven't stated what your actual failure is.
Brian
"What's that unusual keypad for under a cover to the left of the door open indicator? "
Hmm,
I will have to stop posting pictures on my posts, you guys are too observant.
In fact it's the head unit of a converted pmr transceiver, working on the amateur band.
But you made no comment on the tomato sauce bottle.
I am not giving the reason for that away !!!...
Hmm,
Well thats obviously to collect the anti-freeze/water mixture from the heater matrix when it leaks and then all you have to do is pop the contents back into the radiator/expansion tank when it it gets fullBrian wrote:But you made no comment on the tomato sauce bottle. I am not giving the reason for that away !!!...
Surely it can't be used for any other use
- x 116
I noticed on ebay recently that Chevronics in Hitchin are selling remanufactured heater valves for £55.
I have never dabbled with these things cos I have never had to but it seems that the heater tap is capable of being opened up and repaired and bolted together again.
Anyone tempted??
Anyone tempted??
kiwi
- x 4
I have in the past dismantled and reassembled one of these taps its any easy job to do just the taking out and reinstalling in the car is the birch
The problem really comes down to how flimsy the control cable mech is. I have found in the past that manually wriggling at the tap itself tends to dislodge the crud thats built up eventually. Only snag there is its not exactly doable when you are driving at the same time
Hence Modification to the control
kiwi
- x 4
