New from The Netherlands: GT/Digit Turbodiesel Automatic
hel1
Post by hel1 »
been driving this contraption last saturday, and I must say: why didn't the French think of this combination? but then again, maybe there is a reason and Alcyone will find out shortly :P
Alcyone
Post by Alcyone »
I've built this homemade panel because I want to give the interior a theme of an aircraft cockpit. Currently main power 1 & 2, dashboard, pre-start glow and starter are switched through it, circumventing the ignition lock, which is only left in place for the steering lock. I want control of most functions, arresting the engine is done with a knob & cable, the same kind is used for the cold start. Further mods are in the pipeline like front-rear independent ride height control, custom dashboard with a lot of digital readouts, Hydractive and a blow-down turbine to drive the alternator.
More stuff on the way.
Amsterdam Radar: "UK747 stop climb flight level 210 for noise abatement"
UK Pilot: "Confirm stop climb FL210 for *noise*?"
AMS Radar: " Yesh Shir there is an aircraft above and you'll make a big noish when you hit"
Its like something out of NASA :lol: Very interesting, look forward to seeing further developments.
rayfenwick
Post by rayfenwick »
I agree! I love the Digit (I've had thoughts about making Digit dashboards.. I must be mad.... :roll: )
Looking forward to more pictures and info :)
Ray
www.citroencarclub.co.uk
