Scarecrow's 14TGE
The front spheres look as thought they've been fitted with those valves which allows the spheres to be re-gassed?
scarecrow
I wondered what they were! The spheres were regassed last week - the mechanic said they hadn't gone past the halfway point beyond which the diaphragms are damaged. I can't say I noticed any difference in ride quality afterwards... I bowed to greater wisdom though as two independent garages said that the front needed doing..
The car goes back in tomorrow for a tune-up, possibly a thermostat too as it takes ages to warm up and then it's still cool. A new bit of exhaust.is needed too. As soon as that's all done I'm off for a proper test drive somewhere nice.
The suspension should be soft and supple, easy way to test is with the engine running try pushing the front end of the car down yourself and see how stiff it is. I had a similar problem with my 16TRS, the front end was very hard although new spheres were fitted, turned out to be very sticky struts, a liberal dosing of Grease cured that.
scarecrow
Whats the best way to re-colour bumpers on a BX? I've used satin black spray cans and plastic primer on my MK2 astra.scarecrow wrote:Bumpers need doing - I think I'll get them sprayed in the summer.
Rhapsody in blue.
For olympic blue, blue bumpers look much better than black in my opinion. What is the colour code/name for the bumpers on this one? Looks good!
2007 Lexus RX 400h SE hybrid
2013 Lexus RX 450h Luxury
scarecrow
The bumpers on this type are not actually painted they were colour impregnated and they were never the exact same colour as the body leaving the cars two tone.
scarecrow
Yes I agree with that, I'm sure colour coded would look much better than two tone. I did mine grey as I didn't like the two tone look and wanted to keep the TGD basic looking and I have my white TZD for the colour coded look.
Mark Dunmore
If you ask the right bodyshops, they may be able to do the correct "textured" paint for these bumpers; can't remember how it worked, had some sort of plasticiser in it, but it dried with the matt textured finish as per the original impregnated bumpers. New replacements usually came in grey primer (apart from those with the black upper section...)
'71 Dyane project
'74 2CV6 project
'71 Dyane project
'74 2CV6 project
