This morning when i first pulled off the drive the steering had no power assistance. It was solid.
I drove 100 yards then turned right, still really heavy to a point where i could hardly turn it.
I pulled the steering wheel sharp left then sharp right a couple of times and all of a sudden it went back to normal.
What the hell caused that?
Steering Woes
Ian_Fearn
Steering Woes
Over and out from me
Mike E (uk)
heavy steering
My guess is a worn out hp pump
, or loose hp pump belt.
Cold weather makes this worse.
Mike
Mike
DavidRutherford
- BX Digit man!
alab
I didn't think they were that heavy without PAS. Mine didn't work properly until I changed the pump and was no real problem. I mention this as if the steering was that stiff it would suggest a rack valving problem - and you were fighting the mechanism - or in fact moving a piston in a nearly sealed ram full of LHM!
Was this just heavy steering or did it feel that something was jamming it?
AlanS
I've never heard of a pump just dying that quickly and then just as quickly getting resurrected again.
I'd firstly look at the belt and if a new belt didn't sort it, look at the piniuon seals. PProbably easy enough to check them; just look to see if they are leaking directly below the hardydisc.
Alan S
Alan S
Mr B
- Northern Moderator
tim leech
BX 16v Ph2 - XPO - x 103
Ian_Fearn
