4x4 Estate needing a home
richardd1652
Post by richardd1652 »
Do they all suffer 4x4 problems or is it mainly from abuse/towing etc?
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
richardd1652 wrote:Do they all suffer 4x4 problems or is it mainly from abuse/towing etc?
Richard.
All 4x4 models suffer the same problems or failure, exhausts are bespoke and unobtainable!
messerschmitt owner
Post by messerschmitt owner »
Richard.
an exhaust is nothing but some piping, a silencer box or two and a catalyst (if needed). I'd be off at an exhaust manufacturer for one - if I can get one for my 1959 messerschmitt, I could get one for a BX 4x4 in mild or stainless, or even carbon fibre or titanium!
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
I think the only way to get one would be as you say have one made up out of stainless, then ones its done its done. Thankfully the 4x4 are pre cat models.
JayW
x 13
Post by JayW »
OK, slightly confused... is the car in Camborne or Cambridge?
x 103
The 4x4 saloon exhaust is decidedly simpler (imho) than the regular BX one, so it really shouldn't be an issue.
On the cog box side, i think this idea that towing causes the problem is a bit of a red herring. My understanding is that the damage is caused solely by aggressive driving, both hard acceleration, sloppy gear change, dumping the clutch and J-turns.
The flipside is that i've driven one that was very heavily abused yet never skipped a beat. I've also driven one that was absolutely imaculate, well maintained and looked after, low milleage and it didn't last very long at all.
If there was a solution to the cog box problem, and having seen pics of one in bits i believe there is, then i wouldn't be too worried about owning one.
rayfenwick
Post by rayfenwick »
Vanny wrote:If there was a solution to the cog box problem, and having seen pics of one in bits i believe there is, then i wouldn't be too worried about owning one.
Thanks for making my day Vanny... one day I'll get one ... :)
Ray
www.citroencarclub.co.uk
Pity they didn't do a diesel :cry:
messerschmitt owner
JayW wrote:OK, slightly confused... is the car in Camborne or Cambridge?
in Cambridge, Glos, at Tony Weston's Citroen garage - just ten miles south of Gloucester on the A38
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
Definately Cambridge, Gloucestershire - Sorry for the confusion.
Will go back round and sort pics etc in the morning.
Keeper of the site Goat
Post by cavmad »
Couldn't you fit a diseasel engine to one though? Ok, it'd be comically slow (in n/a form at least) but would probably put less strain on the chocolate 4x4 system.
Vauxhall apologist.
I wonder if they made a diesel one on t'continent? A BX TD 4x4 estate would be a great piece of kit
electrokid
Post by electrokid »
It certainly would, but...
If its a 4x4 estate it will be the 1905cc carb fed petrol 105hp unit.
would do very nicely too. I'm seriously taken by the idea unless Doc wants to snaffle it for Smiffy. I had a 2 litre Granada saloon with 106 bhp and that was a fine motor - and 300 Kg heavier !
If you told me it was fitted with a Weber carb as well I'd have to increase my medication :lol:
Looking at the drawings on the Citroën TIS the rear diff looks standard enough - is it the transfer box / viscous coupling that go wrong ?
I went to Cambridge of course...
sadly only for 2 days upgrading some software for VAG :-)
cavmad wrote:Couldn't you fit a diseasel engine to one though? Ok, it'd be comically slow (in n/a form at least) but would probably put less strain on the chocolate 4x4 system.
A diesel has more torque though doesn't it Cav and thats going to equal quicker damage despite slower performance. :(
I'm sure I have a press release stating that a 4x4 break was made with a 1905 NA diesel. So sure I'd almost bet my breakfast on it.
I think a TD would be asking for trouble, although I still love the idea of a 16V 4x4 with Activa setup.
Since BX's seem to have dried up on the bay then I'll most likely go have a look at this 4x4 on Saturday after delivering 3/4 tonne of Lance rear axle to the farm. Assuming Smaiffy likes the idea that is!
It's certainly handy given that the Westons are 10 minutes away.
