TZD Estate on Ebay
richardd1652
TZD Estate on Ebay
http://cgi.ebay.co.uk/Citroen-BX-Tzd-Tu ... 1c1a28c80e
Leak on rear suspension, ex CCC Member.
Near you Tim?
Richard.
Near you Tim?
Richard.
electrokid
jacksun1987
My grandad keeps saying to me i should have got a eastate. How bad do you think the suspantion would be.
Ive always like the dark green ones for some reason.
PAUL JACKSON
cosa 1.2 brezze 150 k had
richardd1652
- x 27
Jayboy
It doesn't sound like it's any more than a return pipe issue with the rear suspension. Looks tidy too, so could be a bargain!
CCC BX Columnist
'89 16v P1
'93 ZX Volcane TD 3 Door
'98 Xantia Activa P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
'89 16v P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
richardd1652
He responded to my question in regard to rust and it is the one that was on before.If you look closely at the n/s picture you can see the big scab he didnt mention till i prompted him,he also then mentions scabby arches. My last TZD Estate went in just the same spot.Is it a weak spot on estates?
Richard.
Richard.
- x 27
Issues with estates and their tendency to rot in the rear wings (especially the nearside IME) is linked to how the BX estates were made. Citroen provided Heuliez with the shells etc, (nicely rust protected) and the latter welded their estate-specific parts to them (which were less well protected). It's the same with the Xantia estates.
(And, I think, the XM).
jacksun1987
richardd1652
jacksun1987
theres 3 days left on it it will easy go up. can it still be drivern like that. He said about a trailler
PAUL JACKSON
richardd1652
jacksun1987
Its about 45 miles away. Its not to bad if i get it do you think. It will be better then the one ive got?
Im trying to weigh them both up.
Mines got a towbar towing pack 2 fans body work superb cluch very nice bosch fuel pump.
On the down side Leaking oil battery light comes on arm bearings needs doing Steering gaitor. Possibly a new hp pump.
On estate. Looks like a complete car. ie no odd doors or boot lids. So i wonte have to worry about making it look right every time i look at it. He doesnt mention anything wrong aport from the leaking pipe. And the rust.
PAUL JACKSON
