took the head off a while back, put it all back together apart from this.
engine runs fine (well apart from when you start it from warm when it takes a few secs to maintain idle) but the water temperature dial on the dash doesn't work, oil temp does though (if that makes any difference)
if you feel further down the cable their are two little single pin plugs that plug into the back of the engine.
would love to find a home for it, I look for somewhere every time I open the bonnet and fail
thanks
