Breaking 1.9 TGD
richardd1652
Breaking 1.9 TGD
Post by richardd1652 »
Its off to the crusher soon so anyone wanting parts please drop me a message. Up and running and at the moment can be heard so.Pumps up and drives. Been sat in an orchard/garden about 8 years after failing its test on rot so its well beyond saving. Im going to take the removable panels off. Interior is wrecked but may yield useful bits and bobs.
Richard.
rayfenwick
Post by rayfenwick »
Hi Richard
I'd be interested in the sunroof if it's not all rusty inside (the metal lip visible under the glass if you're sitting in the car) and also the octopus if it's usable. I'm guessing there's no plip :D
I'm sure you'll grab lots of useful bits anyway - it's not like you won't find them a home :)
Ray
www.citroencarclub.co.uk
richardd1652
Tg spec didnt get remote locking as far as i know. Amazingly its LHM "tight" even after sitting on its belly on grass all this time.Your more than welcome to inspect octopus Ray if your passing.I shall look at sunroof next time im up.Probably this afternoon or in the morning for you.
Richard.
Stinkwheel
Post by Stinkwheel »
How far are you stripping it Rich?
I wouldnt mind a spare front height corrector sometime or another.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
rayfenwick wrote:Hi Richard
I'd be interested in ......................the octopus if it's usable.
For a dirty job requiring 3+ hours labour, is it worth reusing an already degrading rubber part that can be bought for £30 new? :?
I'm with way2go on that point Ray, just don't take the risk, imagine once its fitted & it goes again shortly afterwards, you'd probably then just scrap the car, far better to get a brand new one fitted.
rayfenwick
Quite agreed guys, But considering my last "new in packet" one failed instantaneously, I want to get a working setup with an old or even bodged octopus first, then do a pipe-for-pipe substitution with a new one. Make sense?
Ray
(I feel bad about this Ray) Not my fault exactly, but if I can source a replacement by calling in a favour I will and let you know.
rayfenwick
Hi Phil
Sorry if it seemed I was inferring any blame on your part - I've no reason to suppose anything was wrong with the octopus you sold me.
It does however encourage me to try a used octopus first to see if I can get to the bottom of whatever the problem is without another new one dying - finances are somewhat terrible at the moment :(
Ray
Mike P
Post by Mike P »
Richard,
I'm after the "female" headlight mounting cups, if you understand that description :roll:
Not the adjuster rods that fasten to the front metal panel and not the complete headlights.
There are 3 off on each headlight, so 6 in total.
If you are willing to smash the headlights apart that is :?:
Mike P
rayfenwick wrote: It does however encourage me to try a used octopus first to see if I can get to the bottom of whatever the problem is without another new one dying
I think that you are still missing the point though Ray, that the octopus is not (naturally) under pressure. The car can be tested without it, hardly any LHM should come out of orifices when suspension is going up or level. It will normally shed LHM when going down though so catcher pans and newspaper is advisable!
Have you checked for abnornal strut leakage yet?
richardd1652
Ray, sunroof looks good from underneath but couldnt get it to open this evening. I ran out of time and daylight but your more than welcome to come over and have a play with it.
Richard.
rayfenwick
Way2go wrote: I think that you are still missing the point though Ray, that the octopus is not (naturally) under pressure. The car can be tested without it, hardly any LHM should come out of orifices when suspension is going up or level. It will normally shed LHM when going down though so catcher pans and newspaper is advisable!
Well the problem is that we've been unable to recreate the scenario with p!ssing LHM or any pressure. The struts returns don't give anything more than a few drops a minute, yet something somehow necessitated someone putting a jubilee clip on the old octopus, and destroyed a brand new one. Given not all the pipes were connected when we started looking (perhaps these blew off when the car sunk after turning it off when we got it home from Richard's), and pipes have been cut/bodged, it's not easy to know if everything is/was connected correctly. We tried to follow what was there, but it seems that starting from scratch would be the best way, and that's the next cause of action. If I can do it without buying a new octopus, so much the better. Once it's proven to be working fine, we'll do a pipe-for-pipe swap with a new one.
There's a ball bearing in one of the pipes at the LHM tank IIRC - could a missing/stuck/mislocated ball bearing cause it somehow? We're really shooting in the dark....
Ray
rayfenwick
richardd1652 wrote:Ray, sunroof looks good from underneath
Good news.
richardd1652 wrote:but couldnt get it to open this evening.
Bad news. Still, my actual mechanism is fine, it's just the metal frame that the glass is attached to that's rusty on mine. Someone didn't clear the drains it seems...
richardd1652 wrote:...your more than welcome to come over and have a play with it.
Now there's an offer you don't get every day! ;)
Thanks Richard, I'll try to get it organised before Wetherby if I can.
Ray
CGATCX25GTITURBO
Post by CGATCX25GTITURBO »
drivers sun visor :) would be nice... mines starting to give up
missing my 1992 BX19TGD
1987 BX19 GTI 8)
19TD temp 2 Xantia estate :)
600 Bandit 97 :)
ZX12R 00 :evil:
