Learn something new everyday.
Changing the Anti Freeze caused the matrix to leak, well that much was obvious.
What I did learn today is that the longer you leave antifreeze in the engine the bigger that you can expect a whole lot of problems if you do not flush the system well. I have no idea when the TRS had its antifreeze changed last and I have had it 3 years now but never really expected her to last this long on be pressed into service for the expected cold months of winter to come.
Made t
me think though the TZS is overdue for a coolant change, fingers crossed thats not going to be problematic. Last time I chnaged the TZS coolant I had a new head gasket fitted.
Change the Anti Freeze Regular
kiwi
- x 4
Gibbo2286
kiwi
- x 4
I get what your saying.
There was no leaks until I changed the coolant antofreeze/water mixture, then the trouble started.
Did get an explanation of chemical reaction between the differant brands of antifreeze, which kind makes sense. Just one those jobs where I wished I left well alone especially being a vehicle down at the moment and the TRS is needed to be "cough" roadworthy. Last thing I need or want now is the TZS to play up more than it already does.
Brian
I have often read that the corrosion inhibitor in antifreeze deteriorates, but the anti freeze element does remain functioning for a long time after.
That being the case, is it possible to purchase the inhibitor separately, or even use the corrosion inhibitor as used in domestic central heating systems?...
kiwi
- x 4
