So, after spending many hours over the last two days fitting a new oil filler neck (a lovely job), I thought it was a good idea to go for a little drive about to make sure everything was ok before driving to Bridlington tomorrow to pick girlfriend (and her mum!) up.
Anyway, get out on to the motorway, get up to 60 and an ominous whistling noise begins. Now, those who have followed my exploits will note that mysterious noises http://www.bxclub.co.uk/forum/viewtopic ... highlight= are the bane of my BX life. So, pull off at the next junction, check everything I can think of, nothing obvious. Get back in, same noise, I'm now heading round the M60 starting to worry, what could possibly be wrong? Argh, etc. I need some air, turn the fan on, direct at face, ah, that's a bit better, wait, where's the noise? Bloody air ducts must have been at just the wrong angle to cause a whistle. Dammit!
Always check the obvious
Martin
I had something similar in our VW Bora last year - a high pitched metallic clatter that kicked in at precisely 2,700rpm. I spent hours with an engineer's stethoscope poking and prodding, not to mention the test drives.
I must have tightened every securing screw in the dash panel and door assemblies ................... before I found out it was the ignition key hanging from the lock barrel and chattering in its ring.
Herself still gives me grief over that ...........................
Inferior key ring!.....another good reason to give up the modern cars and keep the BX Bob
