Hi guy's,
just looked at my pump and it's leaking LHM so I need a new second hand one. Anybody got one ?
Cash waiting.
Cheers Kev (TZD)
Just bought one on ebay remanufactured for a buy it now price of £20 + £15 postage.
HIGH PRESSURE LHM PUMP FOR TZD (i've now bought one)
tzd
It isn't just a car it is a BX and it's my BX. Long live the BX.
NeilGP
- x 3
Have you checked this out
http://cgi.ebay.co.uk/Citroen-BX-Power- ... 2a11717974
or even contact the seller
Neil
A476 RBX
Series 1 BX 16TRS
A476 RBX
Series 1 BX 16TRS
tzd
lhm pump
Hi NeilGP,I was looking on ebay but typing in something completely different. I think the pumps are the same all the way through the bx production life ? thank you for spotting this one I will definitely be bidding on this one.
Kev
Kev
NeilGP
- x 3
tzd
lhm pump
Hi NeilGP,
I've just been out to the TZD and measured the pulley and it is the 95 mm pulley, lucky really as I have already put a bid on one on ebay.
Cheers Kev
Cheers Kev
tzd
slow to rise
Hi guy's
I managed to get a remanufactured pump on ebay. It took me about 1 hour to swap over.
I managed to prime the pump quite easily by pouring fluid from the supply into the pump before refitting the supply. Started the engine and the car rose within 40 seconds from having no pressure in it at all, all the way to maximum height.
It seems to drive differently now, the steering is lighter and the braking sharper.
Kev
Kev
- x 27
tzd
high pressure lhm pump
Next project,
when I get a bit more money together I am going to replace the front spheres and the accumulator.
Roll on more money.
Kev
Roll on more money.
Kev
tzd
I've done the front spheres on my previous BX before it was written off outside my house some years ago.
Quite an easy job to do as long as your careful about making sure the pressure has been released from the accumulator.
I bought a really big pair of Stilsons to do the job which have been in my tool box ever since, the Stilsons will have there day again.
Kev
Kev
I find just putting the car into the low position with no engine running, wait a few mins & gently unscrew them a bit, put some rags underneath & then a few mins later unscrew them, easy peasy, no need to mess with the regulator screw either if its just the front spheres. Never changed the accy sphere, so you might need to release the pressure regulator screw for that though.
