HIGH PRESSURE LHM PUMP FOR TZD (i've now bought one)
tzd
Post by tzd »
Hi guy's,
just looked at my pump and it's leaking LHM so I need a new second hand one. Anybody got one ?
Cash waiting.
Cheers Kev (TZD)
Just bought one on ebay remanufactured for a buy it now price of £20 + £15 postage.
It isn't just a car it is a BX and it's my BX. Long live the BX.
NeilGP
Post by NeilGP »
Have you checked this out
http://cgi.ebay.co.uk/Citroen-BX-Power- ... 2a11717974
or even contact the seller
Neil
A476 RBX
Series 1 BX 16TRS
tzd
lhm pump
Post by tzd »
Hi NeilGP,I was looking on ebay but typing in something completely different. I think the pumps are the same all the way through the bx production life ? thank you for spotting this one I will definitely be bidding on this one.
Kev
NeilGP
Post by NeilGP »
Hello Kev,
I think the diesel pump has a smaller pulley diameter to the Petrol.
I don't know if these pulleys are interchangeable.
Neil
Neil
A476 RBX
Series 1 BX 16TRS
tzd
lhm pump
Post by tzd »
Hi NeilGP,
I've just been out to the TZD and measured the pulley and it is the 95 mm pulley, lucky really as I have already put a bid on one on ebay. :D
Cheers Kev
tzd
lhm pump
Post by tzd »
just lost the pump i was biding on on ebay any body got one?
Cheers kev
tzd
slow to rise
Post by tzd »
Hi guy's
I managed to get a remanufactured pump on ebay. It took me about 1 hour to swap over.
I managed to prime the pump quite easily by pouring fluid from the supply into the pump before refitting the supply. Started the engine and the car rose within 40 seconds from having no pressure in it at all, all the way to maximum height.
It seems to drive differently now, the steering is lighter and the braking sharper.
Kev
Excellent result. Well done.
tzd
high pressure lhm pump
Post by tzd »
Next project,
when I get a bit more money together I am going to replace the front spheres and the accumulator.
Roll on more money.
Kev
Post by Mothman »
Well done bud,
the sphere's front and back are not difficult to do as long as you follow the sticky on this forum. An excellent guide.
Good luck with it and finding more dosh.
tzd
Post by tzd »
I've done the front spheres on my previous BX before it was written off outside my house some years ago.
Quite an easy job to do as long as your careful about making sure the pressure has been released from the accumulator.
I bought a really big pair of Stilsons to do the job which have been in my tool box ever since, the Stilsons will have there day again.
Kev
I find just putting the car into the low position with no engine running, wait a few mins & gently unscrew them a bit, put some rags underneath & then a few mins later unscrew them, easy peasy, no need to mess with the regulator screw either if its just the front spheres. Never changed the accy sphere, so you might need to release the pressure regulator screw for that though.
