WANTED - initial parts list
Hi folks
Most urgent parts needed for my battered RD are:
Mk1 RHD mirror. Glass is missing, but would take entire housing.
165 width tyres - SORTED. I know some folk upgrade to wider, but if you've got good 165s about the place, I'd be interested.
Wiper assembly. LOTS of play in this one - unless the spindle can be replaced?
Timing belt kit, plus water pump.
I know I can get most of the above elsewhere, but thought I'd check here first!
Gibbo2286
Post by Gibbo2286 »
Can't help with the 165 tyres but I have a pair of wheels here with 185-70-14 tyres in useable condtion (there is a wheel also with a 165 on but it's knacked)
I don't know what the difference is between mk1 and mk 2 mirrors but I have a pair of manual mirrors from a 1991 car.
All yours for free if you can get them collected from GL15 6LE, depends how deep in Wales you are I suppose, I'm about 13 miles from the Severn Bridge.Welsh side. :D
Thanks. Wheels might be of interest. Need to ponder logistics (nr Aberystwyth here).
Mirror is no good as Mk1 mirrors are very different.
x 171
Ian I have a mirror and a set of wheels and tyres you can have mate when I can pick up the wheel bolts from RXBX and fit my alloys.
Or could maybe bring to Stratford?
Tim.
Would you be able to post the mirror Tim? I can hopefully get tyres closer to home but I'll need a mirror for the MOT.
x 171
Yes mate no worries, im away in Germany for a few days with work as of tomorrow so will be when I get back, PM me your address. Did you need a pair?
Tim.
VW gonna teach you how to sell the New, New, Beetle Tim. :wink: Don't forget to collect that leather interior up as well. 8)
x 171
mds141 wrote:VW gonna teach you how to sell the New, New, Beetle Tim. :wink: Don't forget to collect that leather interior up as well. 8)
Haha no its a "Jolly" im off to Wolfsburg to see the factory and pick up my "Graduation" award for passing various courses. The Beetle launch is in November in Spain, and yes I am going 8)
Thanks to Gibbo for the wheels. I shall get them fitted tomorrow. Another step closer to the MOT!
Gibbo2286
Post by Gibbo2286 »
My pleasure Ian, a bit less stuff to move from side to side in the yard. :)
Something else to add to the list. Thermostat (early type) and probably top hose as it's rock hard.
Pretty sure the thermostat has jammed shut, as the engine seems to get hot with no heat in the top hose/radiator at all. Thankfully, I've not run it for a very long time at once, but there was some steam from around the engine... (I fear the heater pipes aren't in the best of condition either). Really wish they fitted these things with a bloomin' temperature gauge! Ridiculous oversight.
You can pick up the thermostat pretty cheap on Ebay but even from a factors I reckon a tenner? It's quite likely you'll have a few issues getting at it though - the housing bolts can become quite well integrated.
I have fitted two temp gauges to both my Mk.1s and it's straightforward - the most complicated part being tapping out one of the old sensors in the thermostat to fit the new sensor. I can advise if you need any help? I fitted something like this as I though it was more in keeping with the Mk.1 dash style. I think I paid fifteen quids two years ago.
http://t1.gstatic.com/images?q=tbn:ANd9 ... w3P538WdoB
Thanks Todd. Something like that looks ideal. I usually try and get the 'stat bolts out with the engine hot - a bit of heat seems to help, though it pays to watch out for hot coolant when it all comes apart!
mnde
Meteor Man
Post by mnde »
Dollywobbler wrote:Something else to add to the list. Thermostat (early type) and probably top hose as it's rock hard.
Chris Salter had a real nightmare recently trying to get new heater pipes for his Mk1 TRD - the ones between the matrix and the back of the block. I think in the end they had to use some Mk2 hoses and sleeve them to fit or something...
Mark.
Drat. Oh well. Nowt that can't be overcome!
