I bought one of these for 99p plus £15.00 Postage, he has sold another 5 since varying between 99p and £16, has anyone else bought one and fitted it. I was wondering if they are any good as mine was just a cheap spares stock item (cheap if it's any good)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0643174361
ebay bargain ???????
Is that the correct one for diesels?
I don't know , he does one with a different diameter pulley too but i've not measured mine yet.
I wonder if the internals are the same in all the pumps regardless of what type they are? What you may be able to do is swap the internals over on a knackered pump?
- x 4
Call me cynical, but I'd be wanting a bit more detail on what exactly had been checked and refurbished as well as on specific model fitments.
In the absence of details I'd be inclined to believe that: "Remanufactured: A properly rebuilt automotive part. The item has been completely disassembled, cleaned and examined", actually meant, at best, "I've jet-washed it and given it a coat of paint."
I'd be happy to be proved wrong.
- docchevron
Given that it's described as "power steering pump" and sold for much less than a recon would cost, I'd be inclined to say it's probably not been reconditioned but painted.
Have you bought one Mathew?
Item as described, lets hope once fitted that it was refurbed correctly aftrall. Member ID mulley911 23-Aug-11 21:56
Citroen BX Power Steering Pump (#200639161712)
Ahem, yes It was a punt as just finding any is hard enough let alone knowing whether they are any good or not.
