Cibx's "16 valve phase 2" 4wd -90
- My Cars: Citroen Bx 16s 4wd, MbE 220 Cdi
- x 12
Hello hello, Yes I have some news, I fixed some under the hood. Before inspection I should change wire of speedo meter it consists of two pieces and my wire to the dashport is broken. New ones no more in Finland, does anyone in U.K. possible have that kind of? Very much interest to have not broken one.
Winter is coming and hope so fun also..
BTW I have some extra 4wd parts so sell If someone has needs.
The Factory new axel to the front rear "male", and used but good to Transfer gearbox "female"
Citroen Bx 16 valve 4wd
That looks ace Just out of interest, what winter tyres have you got fitted? I've got Goodyear Ultragrip 8's on mine, which seem to have come out in tests as one of the best.
Hello, it is common in Finland that coolant liquid is 50/50 % so it can take -40-50 Celsius degree. In winter times it is recommended to use engine oil like 5w 40 fully synthetic. Still the engine's breather can be freeze and blows engine oils out
Winter tires are Michelin X-ices (friction tires)
Cheers!
Cheers!
- x 160
If you want see an old video and the best video it is that, the link was before online. The car is better looking now and there was no oil leaking:lol:
http://www.youtube.com/watch?v=MDDWVJrg52E
