Wanted please, washer spray bar and pipe?
richardd1652
Post by richardd1652 »
Just noticed that the windscreen washer set-up is missing on the Digit, has anyone got a spare? should be the same as mk2 as well i imagine?
Thanks Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
Post by Mothman »
Basically they are very similar Richard, just been outside to compare mine. The Mk 1 has some subtle diferences but basically thy are he same. sorry i cant help though.
Post by citronut »
i keep thinking of making them from a length of mig welder linner, useing all the fixings from the original, thats if you still have it,
Wooscary
Post by Wooscary »
I've replaced mine with some bike brake cable outer with little slices in along the length.
Pretty rubbish to be frank!
:D
cms
Post by cms »
5mm Air bleed pipe off any car you can find it on in a breakers yard works fine. It bends easy and its no problem putting the holes in.
Post by citronut »
Wooscary wrote:I've replaced mine with some bike brake cable outer with little slices in along the length.
:D
they need to be very small holes not rather than slits,
Wooscary
Post by Wooscary »
Well, yes, to retain some kind of pressure beforehand, but try making small holes in brake cable outer! :D
It's a temporary bodge, MOT man liked it.
Post by citronut »
i spoz if the slits worked you might get a fan/missed like modern cars have,
Wooscary
Post by Wooscary »
That's the kind of effect. Although at anything over about 60mph you just get a very clean roof.
Would aquarium air pipe work instead? Its flexible & should be soft enough to make small holes in.
Wooscary
Post by Wooscary »
Sounds plausible. Would be rubbish for brake cable though.
djm666
spray bar
Post by djm666 »
how about buying one from citroen?
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
Nah, why do that when you can bodge a 'solution' instead? :lol:
We always seem to assume parts are no longer available (myself included!) but has anybody checked to see whether you can get this any more? Sometimes bits are cheaper than you think! I remember a guy on a VW forum I frequent proudly saying how he'd got a blacksmith to make him a rod for part of the handbrake mechanism for 'only' £20. I pointed out that I'd simply phoned up the dealer, who had 7 in stock and only wanted £8 including next day delivery... :)
If NLA there is always this alternative from this post from Neil
http://www.bxclub.co.uk/forum/viewtopic.php?t=15371
richardd1652
Been up at the farm and had a route through all my boxes of Bx stuff and ive found a spray bar so thanks for all the advice guys but this is now "ticked off " the to do list on the Digit.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
