Wanted please, washer spray bar and pipe?
Just noticed that the windscreen washer set-up is missing on the Digit, has anyone got a spare? should be the same as mk2 as well i imagine?
Thanks Richard.
Thanks Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
i keep thinking of making them from a length of mig welder linner, useing all the fixings from the original, thats if you still have it,
I've replaced mine with some bike brake cable outer with little slices in along the length.
Pretty rubbish to be frank!
Martin
they need to be very small holes not rather than slits,Wooscary wrote:I've replaced mine with some bike brake cable outer with little slices in along the length.
Well, yes, to retain some kind of pressure beforehand, but try making small holes in brake cable outer!
It's a temporary bodge, MOT man liked it.
Martin
That's the kind of effect. Although at anything over about 60mph you just get a very clean roof.
Martin
Would aquarium air pipe work instead? Its flexible & should be soft enough to make small holes in.
Sounds plausible. Would be rubbish for brake cable though.
Martin
Nah, why do that when you can bodge a 'solution' instead?
We always seem to assume parts are no longer available (myself included!) but has anybody checked to see whether you can get this any more? Sometimes bits are cheaper than you think! I remember a guy on a VW forum I frequent proudly saying how he'd got a blacksmith to make him a rod for part of the handbrake mechanism for 'only' £20. I pointed out that I'd simply phoned up the dealer, who had 7 in stock and only wanted £8 including next day delivery...
If NLA there is always this alternative from this post from Neil
http://www.bxclub.co.uk/forum/viewtopic.php?t=15371
