Thanks Tim! Looks like I might be able to make the trip over to see you in the actual car, just still not sure when. I don't need any more wheel trims though - I've got three that were with the car (but not currently fitted) and another four from Artic-steel.
The chap has even been trying to pull the dent out of the LH rear door - I told him it's not worth bothering really. It's quite rusty (albeit not as rusty/broken as the LH front door!)
On the subject of seals - the door and window seals on the offside are completely knackered. Can you get them and what are they like to fit?
- x 160
She's back! Bit of a crisis on collection as the fuel filter housing had developed a pin hole and she wouldn't start. Bodged it with chemical metal to get home but does anyone have a spare fuel filter housing? It's the long, metal type.
New tailgate is in place, so she's actually useable as an estate for the first time since I bought her. So much more refined now there isn't a huge hole in the boot floor and air escaping around the wonky tailgate! None of the work is pretty, but she's considerably more solid and it set me back a reasonable £300. I've still got to sort the wiring out. The chap wired up the number plate lights before admitting defeat - the joys of French wiring! However, to be fair to him, that leaves the car in the same state it was in when it went to him ie the HRW and rear wiper don't work.
Pics to follow later.
Found it.
Is this the one you mean? It measures 14.5cms by 8cms at the rim.
All there but will need a slight clean inside and out.
Andy[img][img]http://i222.photobucket.com/albums/dd12 ... re1514.jpg[/img][/img]
- x 160
Here are the pics. I've now upgraded to a Mk1 19TRS estate!
Tailgate doesn't entirely match, but then it's hard to find any part of the car to match to...
I'm very impressed with this repair given how thin the roof metal is. Very little distortion.
'Temporary' repair to the rear wing. Much better! Again, the paint match was judged unimportant at this stage.
This bracket for the rear bumper is all bent out of shape. Can you get them anywhere? Are they the same as the hatch?
- x 160
- x 160
- x 160
