Gti fuel filler neck wanted
Has anyone got a fuel filler neck? Mine has succumbed to the tin worm.
- JayW
- x 13
There are 2 lengths of filler neck. 1 is used when there is no auxilliary tank (basic & diesel models). This longer one couples to a rubber pipe and then to the main tank.
And a different one on the cars with auxilliary tank (turbo and high spec cars). This shorter one connects directly to the auxilliary tank behind the rear qtr panel.
I suppose the easier question is: Do you have the additional fuel tank in the void between the rear inner & outer wing (below the filler flap)?
This will help you to identify what you need
http://www.bxclub.co.uk/forum/viewtopic.php?t=14341
though where to get one ??
- Vanny
BX 16v Ph2 - XPO - x 82
It should also be noted that there is a third option, for the 16v. It has a narrower intake so will only accept a petrol fuel hose, it has a separate part number. It was available to buy in 2004, when i bought one, fitted it, couldn't get a diesel fuel hose in and sold it, however it is no longer available in 2012 and i could rather do with it!
Thanks for the replies and the link. I presume it will have the additional tank. I will have a look tomorrow. If I can't source one I will make one out of stainless or carbon fibre.JayW wrote:I suppose the easier question is: Do you have the additional fuel tank in the void between the rear inner & outer wing (below the filler flap)?
- smiffy1071
- pies are evil!
- JayW
- x 13
Fnarrrrr...
As the actual bayonet is NLA, 4B4 was asking for a complete replacement neck i believe. Which is either 1 or 2 above (complete with the bayonet already attached) and dependant on whether he has the aux tank or not.
Which is exactly what was trying to be ascertained.
- electrokid
