1991 gti
Re: 1991 gti
citsncycles wrote:I would have happily pitched my old 14TGE against the valvers and oil burners on the Challenge this year.
Yeah, but instead you happily pitched a 1200cc GS against the valvers and oil burners! And didn't do too badly...
I guess that people are now snapping up cars they wanted to have when they were new, and more people hankered after a 16v, even if (perhaps) they would actually enjoy another model more.
Re: 1991 gti
I've got fond memories of my 8v Gti, it went very well & was a relaxing drive if i was taking it steady & had plenty of oomph when needed & i once managed 36mpg :)
Re: 1991 gti
When it comes to driving cars I follow James Hunt's line of thinking - his daily driver was an A35 van, his reasoning being that with such a slow, low powered vehicle he could have much more fun at legal speeds than in some high powered sports car. I certainly had more fun pushing the GS towards its limits than I would have driving a car that was able to go round those bends much quicker!
maxgreenwood
Re: 1991 gti
Post by maxgreenwood »
the Gti manual i find to be a very relaxing drive, but loads of power when you need it. I find it economical as well, probably i think because it's so light and you can trundle around town at 1-1500 rpm all day cos of the low end torque and it just ticks over really solidly at those low revs.
I get around 35-40 mpg on a run 60-80mph, being careful and it will do 45mpg. Around 28-30 round town.
My only bugbear with it is the exhaust is noisy, in a hot-hatch kinda way, certainly compared to the 16 carb which is quiet. But it does have a stainless steel exhaust from the downpipe onwards so a different setup might help.
Tim, i'd be interested in how the TZi is on that front. Bearing in mind i'm probably more (over?)sensitive to sound as it's my profession.
'90 16TZS (m), White, 86k
mike22861
Re: 1991 gti
Post by mike22861 »
the 8v 4x4 is about the same feel as the 2wd power wise as it biases the front wheels 53% to 47% under normal driving the transfer diff is freewheeling the rear drive train so very little power loss. when you loose the front end grip lots of power isn't the answer anyway but i do like the way when pushed on the limits the 4x4 starts to under steer you feel a slight shuffle and then you get your steering back and the back end hunkers down a bit and away you go sadly it still cant touch the activa on corners but the activa has a habit of feeling perfectly composed and you wonder what the screeching noise is then you realise its all four tyres bitterly complaining thay dont want that much sideways G it's not unusual for the activa to corner with all four wheels sliding the BX 4x4 never does that. The 2wd Gtis ive had had a nasty habit of spinning away from junctions the 4WD cures that
1992 BX 4x4 Gti aircon Silver
some other newer Nissans
hilarystone
My Cars: Citroen BX 16V, BX Van 16V, Visa GTI, CX Ambulance Turbo diesel, Xsara VTS Phase 1 and 2, Lotus Elan 1970, Clan Crusader, C8 2l petrol, 1982 GSA Pallas, 1974 GS Birotor
Re: 1991 gti
Post by hilarystone »
I don't agree the handling; the 4x4 is a lot more neutral and it really is not a lot slower through the corners than an Activa. Of course it rolls (and quite a bit more than a 16V) but once you overcome the fear induced by body roll it can be stuffed through roundabouts and corners a lot faster than a standard BX and will surprise many modern hot hatches... The 16V is lot nicer in feel when driven hard than a standard BX but ultimately understeers more than the 4x4. Unworn grippy tyres make a lot of difference on the 16V - worn front tyres dramatically increase the understeer.
Hilary Stone
http://www.Hilarystone.com
