I have a set of 4 alloy wheels + original steel spare for sale.
They came off a 1995 405 GLX TD.
The tyres are all good KWIK FIT make 185/65x14 + spare Pirelli
Complete with alloy centre caps.
As far as I know they will fit a BX
£75
Set of 4 Alloy wheels + steel spare -50%
Just the 0 BX
1 TZD Turbo a/c going going GONE
1 TD Hurricane being broken up for spares
3 FIAT 124 Sports!!!
1 FIAT 124 Spider ex. California
Oh and I nearly forgot
A LOVELY XANTIA HDI EXCLUSIVE ESTATE
Hi Bernie, I have had a set of those alloys, they will fit a BX with slight modification, you need to drill holes to accomodate the wheel locating pin on the bX rear hubs and to open the hole in the middle out by a few mm to allow the rear hub centre to fit. all simple really.
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Dependant on width they should fit a BX though if they are going on a GTi or 16V they`ll need to have `H` or `V` rated tyres, anything slower then `S` or `T` rated should be fine.
Hope this helps, btw Bernie have you tried one of the Fench car forums? I`m sure someone will snap those up from you.
Vauxhall apologist.
- DavidRutherford
- BX Digit man!
DavidRutherford wrote:
The caps alone will sell for about £10 each on eBay!
Should I put them on ebay or put the price up???????
Just the 0 BX
