Set of 4 Alloy wheels + steel spare -50%
bernie
Likes welding rusty Fiats.
Post by bernie »
I have a set of 4 alloy wheels + original steel spare for sale.
They came off a 1995 405 GLX TD.
The tyres are all good KWIK FIT make 185/65x14 + spare Pirelli
Complete with alloy centre caps.
As far as I know they will fit a BX
£75
Just the 0 BX
1 TZD Turbo a/c going going GONE
1 TD Hurricane being broken up for spares
3 FIAT 124 Sports!!!
1 FIAT 124 Spider ex. California
Oh and I nearly forgot
A LOVELY XANTIA HDI EXCLUSIVE ESTATE
Stewart (oily!)
Post by Stewart (oily!) »
Hi Bernie, I have had a set of those alloys, they will fit a BX with slight modification, you need to drill holes to accomodate the wheel locating pin on the bX rear hubs and to open the hole in the middle out by a few mm to allow the rear hub centre to fit. all simple really.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Keeper of the site Goat
Post by cavmad »
Dependant on width they should fit a BX though if they are going on a GTi or 16V they`ll need to have `H` or `V` rated tyres, anything slower then `S` or `T` rated should be fine.
Hope this helps, btw Bernie have you tried one of the Fench car forums? I`m sure someone will snap those up from you.
Vauxhall apologist.
bernie
Post by bernie »
Thanks Stewart
The tyres are H rated
Just the 0 BX
The center caps for those 405 wheels are like gold dust. There's an accepted modification to drill and tap a hole in the wheel, and then bolt the cap on, as otherwise they dissapear within seconds of being fitted.
The caps alone will sell for about £10 each on eBay!
Stewart (oily!)
The set I bought a few years ago had little bits of duct tape tightening up the clips, your suggestion sounds good David, I sold mine to a 405 owner and made a small profit :P
Stewart
bernie
Post by bernie »
Should I put them on ebay or put the price up???????
Just the 0 BX
bernie
Post by bernie »
£50
Just the 0 BX
