Jaba getting down and dirty
x 83
Heres a pic of me in the spring changing over a front brake caliper..........
There is a reason for posting this. I had to change that caliper, it was a reconditioned one from ebay, as it did not ever adjust the hand brake action so I eventually lost the handbrake on that side and ran out of handbrake lever travel.
I want to dismantle this recon caliper and put in some innards from an old caliper that is otherwise worn out - it clonks badly on reverse - but I have never been able to successfully do this as I do not have a tool to compress the dished washers to enable the caliper to be reassembled.
Has any ever done this ? What did you use. Anyone got the proper tool perhaps. All offers gratefully accepted.
Re: Jaba getting down and dirty
Post by citronut »
someone on the FCF has just reported unscrewing the piston from a XANT caliper,
so if this is possible it might take the load off the dished washers,
dont know for sure as i have never taken a caliper apart
That's a nice pic - reminding me of sunny days now that all has turned white out there again.
Maybe you could try a large G-clamp pressing onto an appropriate sized socket for the job? Otherwise go and ask if you could borrow the special tool from your local Citroen garage?
I'd be interested to learn on this one.....mine clonks terribly in reverse.
