number plate lights
x 138
number plate lights
can anyone tell me where the power supply comes from for the number plate lights as mine are not working, both rear lights work ok but 0 power to NPL, i guess they also need a ground as its plastic tail gate, thanx
kiwi
Re: number plate lights
Post by kiwi »
Have you checked the bulbs and the way they connect first?
BX number plate lights notorious for working one send and not the next a common fix is to open and gently slam the boot closed and they work. But this action also dont do bulb filaments much good either.
1990 BX19 TZS Auto 06/11/1989
RobC
My Cars: 1991 Citroen BX 16v
x 30
Post by RobC »
power supply for the number plate lights comes from the back of the nearside rear light cluster. I think it's the small white 3 pin connector with yellow wires? Can;t remember which wire tho.. but easy enough to work out with a multimeter!
x 103
i seem to think that the ground is in the same place (bolt into the body with a wide range of wires running to it.)
If all the above check out, check that the wires into the tailgate on the nearside aren't broken.
