number plate lights
number plate lights
can anyone tell me where the power supply comes from for the number plate lights as mine are not working, both rear lights work ok but 0 power to NPL, i guess they also need a ground as its plastic tail gate, thanx
Re: number plate lights
Have you checked the bulbs and the way they connect first?
BX number plate lights notorious for working one send and not the next a common fix is to open and gently slam the boot closed and they work. But this action also dont do bulb filaments much good either.
1990 BX19 TZS Auto 06/11/1989
RobC
- x 30
power supply for the number plate lights comes from the back of the nearside rear light cluster. I think it's the small white 3 pin connector with yellow wires? Can;t remember which wire tho.. but easy enough to work out with a multimeter!
1991 Citroen BX 16v
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
i seem to think that the ground is in the same place (bolt into the body with a wide range of wires running to it.)
If all the above check out, check that the wires into the tailgate on the nearside aren't broken.
