Estate parts Required
- x 149
Pair of estate specific (think they are different to hatch) tailgate gas struts
Early S2 (86-89) small square side repeater.
Cheers!
Rear Mudflaps (no rush)
Cheers!
Re: Estate parts Required
I have a square spare side repeater Tim,
are early MK 2s any different to the later version?
- x 149
Yes buddy they got bigger, they are interchangeable but wanted to keep her "stock" as she's so rare.
http://www.sgs-engineering.com/gas-stru ... citroen/bx" onclick="window.open(this.href);return false;
Found these on my internet travels
Land Rover Discovery TD5
^^^ What Discoil says. Got a pair for Timex. No point chasing second-hand ones. They'll probably be knackered too.
Also Tim, there only down the road from me too !Discoil wrote:http://www.sgs-engineering.com/gas-stru ... citroen/bx
So I could pick them up for you if needed ?
- x 149
Thanks Richard, will probably take you up on that.
I do have a few of these side repeaters Tim, suposedly from early MK 2s, ile check them tomorrow for you.
- x 149
Cheers buddy, they are the smaller type as fitted to Kitchs Estate if you need a closer look. Same as peugeots from the late 80's
- x 88
Estate's got the same as the 16v Tim. Pretty sure it has anyway.Tim Leech wrote:Cheers buddy, they are the smaller type as fitted to Kitchs Estate if you need a closer look. Same as peugeots from the late 80's
- x 149
There was 3 slightly different sorts of side repeaters
1. Late mk1 round type
2. Early mk2 square type
3. Late mk2 more bigger and flatter
I'm after the second please. If you put items 2 and 3 side by side there's a marked difference.
Cheers!
Cheers!
Well there you go. I'd never noticed that one!
Hi Tim,
you will be pleased to know that i have a pair of these. A tad smaller than the later MK 2s.
