Stuck-up TZD
Dominic
Stuck-up TZD
Forgive the repetition - I read about this issue on the forum just a few days ago, and now can't find it... The height control lever in the cabin on my TZD is resolutely stuck in the mid-position. I had a cursory look at the linkages underneath yesterday and they seem free and well-lubed, but the hand lever is stuck solid and I desperately need to change the spheres, so I have to address this asap. Can anyone remind me what the solution was?
Dom
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
Anything that turns money into noise...
91 TZD
02 Picasso HDI
'12 DS5
83 Moto Morini 500
70 Fiat 850 Spider
Re: Stuck-up TZD
You might get some joy by removing the centre console and trying to lube the mechanism there. That's the same option. The linkage underneath needs a bit more care in case the car suddenly drops. I would have thought that with the car safely on stands, undoing the pressure regulator bleed screw would depressurise the system enough for spheres? I'd like confirmation of that before you give it a go...
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: Stuck-up TZD
/\ But the car will drop and pretty damn quickly unless you're able to undo the bleed screw just a tiny amount but I really wouldn't do this unless nothing else works.
I've never had one stick so I don't know if there is a typical cause/remedy but doing as Dolly suggests (remove centre console) is probably your best bet. Also consider underneath of the lever (outside of the car) this could possibly get jammed without lube
Re: Stuck-up TZD
That's why I said get the car on stands before you - it would be a pretty sudden depressurisation so it certainly has an element of risk.
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: Stuck-up TZD
Sorry DW my bad, I read it as ramps for some strange reason.
Re: Stuck-up TZD
the car shouldnt sink that quick by releasing the bleed valve on the regulator,
you will still need to lower the suspension with the height lever,
the usual point they get stuck is the rear pivot linkage which hangs from the rear axle cross member,
the linkage pivots on a bolt thread so becomes stuck quite readily, as said above with the car safely supported, unhook the front to rear height rod then work and lub work and lub work and lub work and lub the linkage at its pivot point till its floppy free/loose, then re/attach the height rod,
they dont/cant usualy get stuck/tight at the point the height lever goes through the floor,
because as it drops through the floor it just pivots on a right angled rod sitting in a nylon block, and the very bottom of the lever is just a pig tail hooked into a loop in the front to rear rod
Re: Stuck-up TZD
Without wishing to teach you to suck eggs, the lever needs to be pushed slightly away from you before it actually moves either up or down.
Re: Stuck-up TZD
It shouldn't sink at all...citronut wrote:the car shouldnt sink that quick by releasing the bleed valve on the regulator,
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: Stuck-up TZD
Darn you're right, the h/cs will keep it up.
Re: Stuck-up TZD
*should* either way, best not to take chances, *usual Elf and safety warning etc etc*
Re: Stuck-up TZD
agreedocchevron wrote: *usual Elf and safety warning etc etc*
they make an aufull mess when they mix the red with the green blood
Re: Stuck-up TZD
red blood just doen't have the viscosity to keep a BX up...
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: Stuck-up TZD
/\ not yours anyway, to much alcohol
Re: Stuck-up TZD
i meant if the car squshed you then leaked the green blood over you to bootdocchevron wrote:red blood just doen't have the viscosity to keep a BX up...
Re: Stuck-up TZD
Explanation not needed Malcolmcitronut wrote:i meant if the car squshed you then leaked the green blood over you to boot
