Fuel tank draining!!
ed4ferrets
Post by ed4ferrets »
Any pointers please on effectively draining fuel from BX tanks (my own naturally :shock:) prior to disposal, 1xpetrol & 1x diesel?
'94 XM 2.1TD Break
'63 Renault Caravelle
If it has an electric in-line pump, hook a 12v battery up and take the injector rail pipe of and let it hang into a bucket!
Worked for me!
Stewart (oily!)
Post by Stewart (oily!) »
similar, remove fuel return line under bonnet, plug in little tyre compressor using airbed adaptor, remove fuel feed line, extend to fit in can, switch on (make sure filler cap is closed)
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
DavidRutherford
BX Digit man!
Post by DavidRutherford »
But.
Pumping the tank out will leave about 10 litres that you can't get at. I've removed a fair number of fuel tanks now, having first pumped them out, and there's always around 10 litres left in them.
If you're going to scrap the car, then I would say it's worth the effort to remove the tank and pour it out. After all, that's £20 worth of fuel in both cars.
ed4ferrets
Actually considering the escalating price of fuel perhaps I should just leave them be to increase in value ....... I'm off to convince 'er indoors of my wise decision :lol:
'94 XM 2.1TD Break
DavidRutherford wrote:But.
I forgot to mention to pull the filler neck pipe off and claim the rest! :P
x 82
big nail, bigger hammer?
Barnsley BXer
Post by Barnsley BXer »
Yeah,Whack it,as my daughter says :D :D :D :D :D
1990 GTI 4x4
1992 TZD
richard
Post by richard »
Thats the way I done mine.[/img][/quote]
Keeper of the site Goat
Post by cavmad »
I just get the car on the back of the truck, pull off the fuel line retaining clips then when I have a nice long piece of pipe to play with I snip it and have empty fuel cans at the ready.
I also believe that by removing the bung under the rear seat (as someone has suggested) and using a windscreen washer pump wired up to a battery can do the job.
I`m always a bit wary of things like this though where petrol is concerned: I`m not overly happy with having a spark inducing device (battery) close to an open fuel source and also as running liquid can cause static unless earthed I`m not convinced it`s entirely safe. Is it worth risking life or limb for a couple of quids worth of fuel?
Vauxhall apologist.
richard
Post by richard »
No way would I use something like a washer pump! That is almost suicidal!!!!
I got a hand pump designed for the purpose.
DavidRutherford
BX Digit man!
Indeed. A washer pump is asking for trouble.
A fuel pump from a petrol injection car on the other hand works very well indeed.
ed4ferrets
Thanks for all the info lads, one way or another I should get all the juice out :lol:
'94 XM 2.1TD Break
