Fuel tank draining!!
ed4ferrets
Any pointers please on effectively draining fuel from BX tanks (my own naturally
) prior to disposal, 1xpetrol & 1x diesel?
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
- x 94
Stewart (oily!)
DavidRutherford
- BX Digit man!
But.
Pumping the tank out will leave about 10 litres that you can't get at. I've removed a fair number of fuel tanks now, having first pumped them out, and there's always around 10 litres left in them.
If you're going to scrap the car, then I would say it's worth the effort to remove the tank and pour it out. After all, that's £20 worth of fuel in both cars.
ed4ferrets
Actually considering the escalating price of fuel perhaps I should just leave them be to increase in value ....... I'm off to convince 'er indoors of my wise decision
'94 XM 2.1TD Break
'94 XM 2.1TD Break
- x 94
I forgot to mention to pull the filler neck pipe off and claim the rest!DavidRutherford wrote:But.
BX 16v Ph2 - XPO - x 103
Barnsley BXer
richard
- Keeper of the site Goat
I just get the car on the back of the truck, pull off the fuel line retaining clips then when I have a nice long piece of pipe to play with I snip it and have empty fuel cans at the ready.
I also believe that by removing the bung under the rear seat (as someone has suggested) and using a windscreen washer pump wired up to a battery can do the job.
I`m always a bit wary of things like this though where petrol is concerned: I`m not overly happy with having a spark inducing device (battery) close to an open fuel source and also as running liquid can cause static unless earthed I`m not convinced it`s entirely safe. Is it worth risking life or limb for a couple of quids worth of fuel?
Vauxhall apologist.
richard
DavidRutherford
- BX Digit man!
ed4ferrets
Thanks for all the info lads, one way or another I should get all the juice out
'94 XM 2.1TD Break
'94 XM 2.1TD Break
