St Tropez restoration blog
Des Smith
Re: St Tropez restoration blog
Ah, yet another reason to join CCC.
Save a fiver at Wicksteed Park, get a valuation and get to read about my own car. Where do I sign?
Xsara Forte 1.4i 2000
Kawasaki GPz550A4 1987
http://www.citroencarclub.org.uk" onclick="window.open(this.href);return false; or members@citroencarclub.org.ukDes Smith wrote:Ah, yet another reason to join CCC.Save a fiver at Wicksteed Park, get a valuation and get to read about my own car. Where do I sign?
There is some discussion over the membership fee, but there would be no National, ICCCR, Stratford, Northern Rally or X Rally without them (and a very good magazine at £2.50 per month), also I think the CCC is aware of the growing publicity of the BX Club after nearly all of the stand members in 2012 were also CCC members.
Des Smith
Done!
Great stuff Des, welcome aboard.
Des Smith
Very Important Day today. The rear subframe, beautifully restored, has been prepared for re-fitting on to the bodyshell. Hopefully, by the end of the day, it will be in place and I can use it as an excuse to pull a cork and toast a step closer to a return to the road. You need to bolt the wheels to something, after all!
Rear subframe being prepared for re-fitting
I'll do the same this evening too - any excuse!Des Smith wrote:I can use it as an excuse to pull a cork and toast a step closer to a return to the road
Des Smith
Cue for a cyber piss-up! BYO and all stand up and toast the St Tropez subframe at 10pm. So what if everyone else thinks we've lost the plot, we'll know the truth!
Des Smith
Far too busy celebrating last night to post this up, but here at last is proof positive of the job done. Looks rather business-like!
Subframe fitted
Subframe fitted
- Reluctant BXpert
Very "like"
If I can get in to Rob's this week for new tyres before CCCE I shall hope to have another peek.
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Looking fantastically new! Are those new sub frame mounts? Do you know of sets available?
barry badger
Are they standard bump stops on the rear? They look longer than usual.
That is fantastic work, they sure know what they're doing. I hope to see it in the flesh one day when it's finished.
1993 tzd estate, on sorn
1992 txd estate, on the road
1991 4x4 estate, on the road
Des Smith
TBH, I'm not sure if they were the originals and have been shotblasted or new. Rob would tell you if you asked.BX Bandit wrote:Looking fantastically new! Are those new sub frame mounts? Do you know of sets available?
Nowt wrong with your eyes! Original bump stops no longer available. Rob has adapted some to fit. Not sure, but they might be from a 747...barry badger wrote:Are they standard bump stops on the rear? They look longer than usual.
barry badger
I thought it might have been a deliberate modification so that one stop does the job of the stop and the rubber 'assister'. It might well work this way anyway.
Sandre , your turning into the St Tropez stalker
