inlet manifold gaskets gti 8v h reg
x 137
anyone got a pic or a link where i can get 1 for this, as i got one from gsf and its wrong, none were fitted so no idea wot the o/e look like, are they 2 piece or 1?
CGATCX25GTITURBO
Re: inlet manifold gaskets gti 8v h reg
Post by CGATCX25GTITURBO »
didn't think they had one :)
missing my 1992 BX19TGD
1987 BX19 GTI 8)
19TD temp 2 Xantia estate :)
600 Bandit 97 :)
ZX12R 00 :evil:
4B4
Post by 4B4 »
Mine did not have one either. So presumably they don't need one.
x 83
It seems incroyable but Citroen never fitted one. You just seal it with silicone which seems to do the job well.
x 137
as a temp measure i made a couple from gasket paper with a smidge of silicone, i should just leave it as is then. misleading tho as they are listed on the bay and elsewhere, and im sure a contributary air leak was happening at this joint as the idle settled a little more after fitting a gasket and sealer.
