inlet manifold gaskets gti 8v h reg
anyone got a pic or a link where i can get 1 for this, as i got one from gsf and its wrong, none were fitted so no idea wot the o/e look like, are they 2 piece or 1?
CGATCX25GTITURBO
Re: inlet manifold gaskets gti 8v h reg
didn't think they had one
missing my 1992 BX19TGD
1987 BX19 GTI
CX25 GTI TURBO CGAT 86 CGAT
19TD temp 2 Xantia estate
600 Bandit 97
ZX12R 00
1987 BX19 GTI
600 Bandit 97
ZX12R 00
4B4
Mine did not have one either. So presumably they don't need one.
- x 116
It seems incroyable but Citroen never fitted one. You just seal it with silicone which seems to do the job well.
as a temp measure i made a couple from gasket paper with a smidge of silicone, i should just leave it as is then. misleading tho as they are listed on the bay and elsewhere, and im sure a contributary air leak was happening at this joint as the idle settled a little more after fitting a gasket and sealer.
