WANTED: 1.6 Gearbox
- JayW
- x 13
WANTED: 1.6 Gearbox
Looking for a 1600 gearbox specifically.
-OR-
Suggestions on a suitable alternative with beneficial ratios if i can't find a proper 1600 one.
-OR-
- x 148
Re: WANTED: 1.6 Gearbox
1.9 carb petrol should be fine with no real performance loss. Also 1.9d will be pretty close match ratio wise.
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
What's wrong with it then Jay? You could always swap the innards over, it's not hard at all. I have loads of bits lying about, all td ratios though, but other bits are common.
Shame you live so far away. I'll look up on cit net later today for you
- x 88
Really? I'm surprised by that! Would have thought the final drive would be much taller in a diesel.Tim Leech wrote:1.9 carb petrol should be fine with no real performance loss. Also 1.9d will be pretty close match ratio wise.
- x 148
According to the brochure for 1.9D theres about 1.2 mph different per 1000rpm (in favour of the diesel) in 5th so not really... (petrol is 21.2 versus 22.4 for the non turbo diesel)Kitch wrote:Really? I'm surprised by that! Would have thought the final drive would be much taller in a diesel.Tim Leech wrote:1.9 carb petrol should be fine with no real performance loss. Also 1.9d will be pretty close match ratio wise.
The 1.7D box has the same 5th ratio as a 1.6 petrol though so if you can find a 17TGD box it should be a good replacement.
A turbo D is much taller at 25.9mph.
So how about you buy my complete BX !
Yes it was/is advertised here and on Ebay and technically sold, except the winner turned out to be playing games and had no intention of completing....
So I shall reiterate : a 1.7 diesel that was converted from a 1.6 petrol. (the ratios seem a tad low for the diesel) Taxed and tested till November, drive away £150. In Norfolk. Red shed.
The alternator has just failed but I'm still driving (short distances..)
It is getting ever closer to the scrapyard, but keeps going.
I tried offering a second chance type thing and got no response. Also as no one on here seems to want it, and I do not wish to break it (too many other things taking precedence..) and the shell is shot, but it does drive pleasantly, like them all I suppose.
- x 148
Shot as in Rotten?, I know cosmetically its a bit challenged but that rectifiable.
Yes rotten, will need welding for MOT and I am not going to do it. But it could be done by someone more willing than I.
Why not advertise it for free on car&classic instead?
Let me know if you cant find one, as I have broken a couple of 1600 BX cars, but it will take me a while to find the g/boxes. If your still in Basingstoke, I am not far from you (Newbury)JayW wrote:Looking for a 1600 gearbox specifically.
- JayW
- x 13
I'll keep you posted, i'm not in Blazingsmoke anymore, but my next trip up is beginning of November.
Cheers!
Cheers!
