Breaking 16v
Re: Breaking 16v
53800 is the Intermotor number. You'll obviously need a T piece if you want to keep the light (I would), but what I found I had to do was put in an extra washer between the T piece and the block, so it became tight in such a position I could screw in both the sender and the switch. If that makes sense?
Re: Breaking 16v
Have you sold the wheels yet ? If not then mine needs 2. A pair of rears got nicked from behind my house whilst my valver was in my garage on axle stands !
