The 16v.....twenty-twelve
x 148
Re: The 16v.....twenty-twelve
Kitch wrote:. It won't look great (paint's worn all the way through in places) but it will look honest. Just got to resist ragging it there and getting it covered in bugs and grime :lol:
[-X You will be sent to the naughty chair....
I've ordered mine from here:
http://www.ebay.co.uk/itm/161006768776" onclick="window.open(this.href);return false;
The last set I bought were very cheap (just printed on the surface of the plate), and have started de-laminating after only 18 months. Hopefully these will be better quality!
mat_fenwick wrote:I've ordered mine from here:
That's the ones I got. They're good quality :)
Excellent! Buy nice or buy twice :(
Stinkwheel
Post by Stinkwheel »
Vanny wrote:It's not a bolt for the compressor, its the bolt for the valver specific idler pulley for the aux belt. The stupid bolt is M8 one side and M10 the other with a spacer/washer of a specific thickness in the middle. Unfortunately because i've only ever had one half of the bolt, i dont know how long the thread should be, whether the thread should be the whole length or not etc
Tried ordering them from Citroen, there are none, anywhere, the parts list doesn't give any length/thread details, there have never been any for sale outside of Citroen, i've never managed to find a scrapper with one, so i'm pretty much stuck. I've looked at alternative arrangements for tensioning the belt, but few give sufficient lap angle over the compressor. I've tried a few 'recommended' alternatives, which haven't worked out.
I'd have thought re manufacturing this a simple task, but without the pattern it's proving rather difficult!
Did you ever get these bolts sorted?
They sound very similar to the ones as used on G's holding the accumulator sphere regulator thingys atop the crossmember in the engine bay. If you happen to have a picture? I believe i have a couple if its the same part.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
