Wanted: Rear O/S rear brake pipe.
adamskibx
I changed a rear arm bearing, and when I went to do up the 24mm nut I had to move the coiled brake line out the way - It snapped. I can see a pipe on Ebay but it's missing the coil in the photo. Maybe it's just a generic photo, but I thought I would ask on here in case anybody has bought one successfully from somewhere, or have a spare one they would part with.
Thanks,
Adam
Thanks,
Adam
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Re: Wanted: Rear O/S rear brake pipe.
May have a brand new one in, need to check. Is it urgent?
here is price and part No. from service citroen
N/S rear
95567450 HYDRAULIC TUBE 11.39 GBP 13.67 GBP 13.67 GBP
O/S rear
95567451 HYDRAULIC TUBE 14.67 GBP 17.60 GBP 17.60 GBP
N/S rear
O/S rear
adamskibx
Thanks both. Its not massively urgent as i am preparing it for an MOT, but sooner the better i guess. I am on a mobile at the moment so ill check out that site later Malcolm. Is that actually Citroen themselves?
Thanks,
Adam
Thanks,
Adam
plaedies? can supply you a pipe for this, you need the amount of coils to allow for flexing of the pipe as there are no rubber flexi pipes on the rear, just measure the entire length of required brakepipe and being made from cupra nickel is quite easy to bend and mould into position.
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
That is genuine citroen parts, I'm guessing shared with the C15. At that price it's a no brainer tbh.
adamskibx
Ah ok, so I would have to go to the dealership to get this I am guessing? I could do with moving the car sooner than next Saturday. I noticed there is a kit with flaring tool on Ebay. Do you think that would work? I would imagine I would have to manually re-create the coiled up bit somehow.
Thanks,
Adam
Thanks,
Adam
- x 8
If you give the dealership the part Nos' they will be in (or should be) next day.
yes it is you have to register, you can then use the parts look up section for free, but tech doc's you pay a subscription for how long you require, from i think half an hour upwardsadamskibx wrote: ill check out that site later Malcolm. Is that actually Citroen themselves?
Thanks,
Adam
heres the link
http://service.citroen.com/" onclick="window.open(this.href);return false;
BX Bandit wrote:That is genuine citroen parts, I'm guessing shared with the C15. At that price it's a no brainer tbh.
nop the C15 has convetional rubber flexi's,
they do show as fitting some of the XANT range though
regards malcolmrutter123 wrote:plaedies? can supply you a pipe for this, you need the amount of coils to allow for flexing of the pipe as there are no rubber flexi pipes on the rear, just measure the entire length of required brakepipe and being made from cupra nickel is quite easy to bend and mould into position.
i think Martin would only make these pipes up out of 3.5mm kunifer,
i have never liked the idea of these being made out of this, as i cant see the coils can keep re/shaping on flexing
Stinkwheel
citronut wrote: i think Martin would only make these pipes up out of 3.5mm kunifer,
Malcolm,
Im fairly sure they would be fine. Think of the large coils inside a 2CV or Dyane rear axle, i believe the coils are there for the same reason that the BX's ones are. And bonaparte and ecas etc have sold many hundred (possibly thousands) for those cars. Im sure kunifer would be fine for the BX ones.
And Adam,
If you measure it up and are prepared to coil it yourself i can also make up the 3.5mm ones for you if needed
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
CGATCX25GTITURBO
My CX Turbo has had coiled cupro-nickle pipes over 15 years, made mine wrapping the pipe around a large socket
made quite a few others for people too
missing my 1992 BX19TGD
1987 BX19 GTI
CX25 GTI TURBO CGAT 86 CGAT
19TD temp 2 Xantia estate
600 Bandit 97
ZX12R 00
1987 BX19 GTI
600 Bandit 97
ZX12R 00
adamskibx
Thanks guys. Matt, that's very kind of you, and he i could i would like to take you up on your offer. Citroen can't get one till next month, and i need to move the car.
Thanks again,
Adam
Thanks again,
Adam
Stinkwheel
No problem Adam, just PM me the length you need and your address. I will knock one up and drop it in the post for you mate.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
adamskibx
Nice one thanks Matt
Please let me know your costs and what you would like for doing it by PM and I'll Paypal you.
Thanks again,
Adam
Thanks again,
Adam
