'The Estate'.............returns?
- Thread Bear
Re: 'The Estate'.............returns?
A message from the anarcho capitalists. 'Bring back the shooting brake' and whose religion, part of American foreign policy, is 'we are only killing you for your own good'.
- x 88
Well, with a tinge of sadness I report that the estate has passed hands. Between Si and myself we've had the car since August 2004, but the time came to change. It drove to the midlands, but made it fairly clear it wanted to stay there
However I'm also happy to report that the car is now in the hands of Tim, who loves BXs as much as a man can! So I'm happy it's gone to a good home.
- x 148
" onclick="window.open(this.href);return false;
Thats why the gears are rather sloppy! no bushes!
Another thing to add to the list for Tuesday!
- x 148
Well a great day for the estate yesterday.....
Two correct colour front wings, dent and rustfree with just a couple of small marks to look at, plus a drivers door also in the correct colour!
Correct RD trims (and steelies to follow- thanks tizzy dee), rear headrests (proper ones) in the herringbone trim ready to match the new interior being collected next week (out of a 40k miles car), gear lever gaiter, knob, loads of bits of trim (parcel shelf support, clock blank and speedo binnacle wing nuts etc) and estate front bumper inserts too!
I have next week off so disassemble will begin in ernest, then I shall be using it to deliver presents over Christmas!
good day indeed!
- x 88
Good work Tim!
- x 148
Arse, the interior I had lined up is missing the side bolsters, thankfully I know where I can get one, and its alot nearer!
- citsncycles
Is it likely to be the same as fitted to a TGD? If so I'm hopefully off to strip parts off the estate I'm told is in Harry Bucklands next Wednesday.
- x 148
Could be depending on the age, it's the red/grey/green herringbone one.
- x 148
What have I done!!!
Work started today, mostly dismantlying and seeing what needs work and what needs replacing.
Carpet, centre console, glove box and seats removed, carpet should respond toa clean, floor pan is solid asides a few bits of surface rust which I will clean up, kurust and waxoil.
Wobbly gearchange be gone! a couple of 2p washers has removed some of the slop but theres obviously wear in the selector rod ball joints, a job for another day.
Front wings, bumper and drivers door removed, the bottom door pin was rusted solid and took ages, glass, lock and door mirror swopped over and new door fitted in place albeit with a couple of alan keys for door pins as it will need to come off again as the top hinge weld is coming away (has been repaired before).
NSF inner wing as you can see is a bit of a state as is the A pillar on that side, which may mean THAT door has to come off too.....
NSF headlamp has been stuck back together but is letting water in (new one sourced) and both inidicator lenses are either cracked or the fixing tabs are shot, (will keep an eye out for a cheapo pair of new ones)
New front wings will be fitted loosley (without wheelarch liners) to allow the car to be driven to Shauns to get the welding done.
My back garden looks like a scrap yard!
- citsncycles
Yep - some of that looks familiar!
- x 148
It's all mendable, hopefully Shaun will weld it up, thankfully it's road legal.
You are doing a cracking job Tim. Hope you will keep this one a while. I will have this to do on my TXD Estate soon and i am going to learn to weld to fix her whether ime here in Sussex or in Cornwall.
- x 88
I've got a new grey carpet and some interior trim in better condition here if you want it Tim?
