were it on here ( plip battery's )
was it someone on here recently asking what battery's are in the BX plip, or was it over on the CCC forum????
if so was the question answered, just in case,
https://www.google.co.uk/#q=v13ga+battery&tbm=shop" onclick="window.open(this.href);return false;
Re: were it on here ( plip battery's )
ps.
found it
twaz over on the CCC forum
found it
Hi Malcolm,citronut wrote:was it someone on here recently asking what battery's are in the BX plip, or was it over on the CCC forum????
I can't recall that request on here, but its all been discussed before in THIS thread, which you also posted in
The original/correct spec. battery for the bulker type 'Tx-plip' (with the Red bladed button) is an '11A' which happens to be 6 volts (When new), 2-off on E-bay for £1.27 !
Click on image for link !
I hope you've given the OP on the CCC the correct info ?citronut wrote:ps.
found it
- JayW
- x 13
My original for the 16V used 3 of the ones Malcolm mentions, as does the one i'm currently selling on ebay. However, a couple of my others used the 11A, they all worked fine.
Never noticed the voltag difference!
I've used both types of battery in the same keyfob, with seemingly no ill effects. Maximum voltage for the TEA5500 chip in the fob is 7 volts, so I guess it matters little.
- Thread Bear
Beware the 'professionally' fitted after-market alarm systems of this era. The Trooper fault has now been found. The alarm was not installed correctly and the service wires mounted lazily where access was easy on the battery end of the live cable. One lead had work hardened its connector in use and the high resistance was what was creating problems with the system. I now wonder if my war against these devices was often the same issue, undiagnosed. The correct mounting for the feeds into the alarm are from the live feed distribution point, not the clamp on the end of the battery. I recommend you consider a tidy up and removal from the clamp end if your alarm is not reliable.
Same guy wired the trailer plug back to front as well. Bright boy clearly. Fortunately my extra upper body mass got me out of that hole by just shoving the plug in the wrong way round breaking the mounting and changing two wires in the light unit. With a load of asbestos roofing panels on my trailer for reuse I would have got the green idiot police excited, if stopped. Love the lichen and moss look and there is no good reason not to reuse this stuff. Especially when it is free and such an idea is banned. Banned substances are so often the best stuff for the job. Like Trich for cleaning electrics like Dynostarters, and misfitted alarm systems.
- electrokid
Chatting with a knowledgable garden centre chap yesterday, seeking advice and to the best fungicide to use on a probable Armillaria mellea infection of my privit hedging, he happened to mention that Copper Sulphate would have been the best if you could still get it. "Excellent" said I: I have lots of it.Banned substances are so often the best stuff for the job.
I also have to creosote the workshop sometime this year... oh yes - real creosote from the stash in the garage
- citsncycles
Oooh, Plip for sale - I'm missing one for Mitch the 4x4! I'll probably have a go on that, once I've found the thread on here about reprogamming them (sure I saw it here somewhere!)
Here you Mike to Jays F/S PLIP-POST which includes the link to reprogrammingcitsncycles wrote:Oooh, Plip for sale - I'm missing one for Mitch the 4x4! I'll probably have a go on that, once I've found the thread on here about reprogramming them (sure I saw it here somewhere!)
- electrokid
Do you mean this...Like Trich for cleaning electrics like Dynostarters, and misfitted alarm systems.
http://www.ebay.co.uk/itm/5-Litres-Chlo ... 3a8437c6b8" onclick="window.open(this.href);return false;
- citsncycles
Thanks RxBX!
