'The Estate'.............returns?
1985 CITROEN BX 19GT C1TBX
2003 Rover 25 1.6i XL L33CHT
x 95
Re: 'The Estate'.............returns?
New bonnet sourced for the old girl as the one fitted is cracked and badly scratched, as are a set of correct silver steelies with good tyres and correct wheeltrims.
Any advise how to get the dirty great hole in the nst arch repaired? its far too big to fibreglass and I wouldnt want to do that anyway.
Matt?????
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
x 57
Tim Leech wrote:Any advise how to get the dirty great hole in the nst arch repaired? its far too big to fibreglass and I wouldnt want to do that anyway.
Some metal, some tin-snips and a welder. I would advise against anything else - we've all seen what happens a few years down the line :wink:
1983 16TRS (Sunrise red) - 1987 DTR Turbo est (Venetian red) - 1989 16 Valve (Venetian red) - 1990 16 Valve (Venetian red)
x 95
I cant and wont weld!
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
x 57
Tim Leech wrote:I cant and wont weld!
Maybe so. However, you can cross the palm of people who can weld with silver, and they'll weld it up for you. Then you just need filler and a bodyshop (or a warm dust-free garage stocked with rattle cans and lots of patience!)
As I remember it there was a bit on the front arches and one of the A-pillars needed doing too, so might make sense to knock them all on the head at the same time. It'd certainly work out more cost effective.
x 95
Matt is quite handy with the welder, so I am sure he can work his magic on the crusty bits then I can get the paintwork done at work,
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
Surely it's cheaper to use steel?
Stinkwheel
Post by Stinkwheel »
Steel is cheaper than silver yep :)
Ive a plan for sorting that hole tim, its probably not as hard as it looks tbh.(he says hoping that hasnt just cursed the whole job to be a swine)
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
x 95
OK Matt, shes in your hands, no rush, but I have some wheel and trims and bonnet for her, plus the clutch in the boot already!
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
Stinkwheel
No problem Tim.
Ive done a couple of quick go overs to see what we have already and what needs attention, always nice to have a worklist :)
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
x 95
Stinkwheel wrote:No problem Tim.
:shock: I can feel a sharp pain in my wallet! :lol:
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
x 95
After a quick chat with mr smith the other day I understand the estate is progressing nicely! I havent seen her since March...
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
x 95
And I must admit to missing the old Girl!
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
Stinkwheel
Not long till the new year now Tim :)
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
x 95
Exciting!!
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
x 95
The Estate is now matt and charlotte's. Things have changed alot in the last year, some bad but mostly good, now in a full time relationship and living together (with someone thats thinks cars are red or blue) being in a new position at work and having 7 cars I just dont have the time to do what I want with them so I have handed it over to matt to finish off the work he has started. I have told Phil I doubt I will be able to the Challenge but I will know for sure by the end of the year.
Over to you Matt!
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1994 Xantia 1.8i SX
1979 Rover SD1 V8-S
