TZD Turbo 1.8TD XUD7TE camshaft options
assembled
My Cars: 1991 Citroen BX TZD Turbo
1989 Citroen BX GTi 4x4
Post by assembled »
Hello, I am overhauling my TZD Turbo and have come up to choosing a better camshaft.
Options with high pressure pump drive on the other end I have:
XUD7TE original
Intake opens: 4°30' BTDC
Intake closes: 20°30' ABDC
lift height: 8.25 mm
Exhaust opens: 39°15' BBDC
Exhaust closes: 3°45' BTCD
lift height: 8.5mm
one from XUD9A (1.9 N/A diesel):
Intake opens: 4° BTDC
Intake closes: 45° ABDC
lift height: 9.2 mm
Exhaust opens: 43° BBDC
Exhaust closes: 0° BTCD
lift height: 9.4 mm
There are some rumors about later being an upgrade performance-vise. It should retain low-end torque and increase high-end one.
There are differences in valve overlap, N/A cam has much longer opening times and greater lift height. This should allow more air in to the cylinder, right?
I have found that there are no differences in geometry of XUD7TE and XUD9 regarding pistons and valves: in both engines valve recess and piston protrusion is the same (please do not hessitate to correct me if I am wrong) so different timings and lift height should not result in piston cathing a valve.
I indend increasing turbo boost to some safe value (to be defined) and putting some more fuel.
Thank you for your input in advance!
1992 TZD Turbo berline, aircon, ABS
1991 TZD Turbo berline
1989 GTi 4x4 berline, ABS
x 141
Re: TZD Turbo 1.8TD XUD7TE camshaft options
Ive heard that fitting a 1.9D cam give better pick up.
N/A cam will give more grunt, purely because the valves open more, and for longer. There must be a downside to the N/A cam (otherwise PSA would have fitted it to all the XUDTs), but I've yet to work it out :lol:
Only downside on a petrol with longer duration and lift is you start getting a lumpy idle and a reduction in vacuum pressure for things like the servo, or mechanical fuel injection if you have it. Diesels have vacuum pumps for that kind of thing, and they combust differently anyway. Hopefully we'll have a definitive answer by the end of this one!
I'm running a 1.9D NA cam in my 1.9TD engine, but I can't give a back to back verdict as I changed the cam at the same time I swapped the engine. It certainly ran well enough on standard boost, and even better at 1.1 bar :)
The earlier square port head had a cam with greater lift/duration from memory, and that head was fitted to Peugeot 205s and 309s right through production. So finding one of those with PAS would give you the provision to drive the hydarulic pump.
I can only think PSA used a softer cam on the TDs for reasons of efficiency - they already had a class-leading diesel in terms of performance so no need to increase that. Or perhaps they were being conservative in terms of engine longevity - I've wondered if that's why they initially used the smaller bore (ie. thicker/stronger cylinder walls) engine when they first developed the TD. Moving onto the 1.9 when real-world experience showed the smaller engine was durable enough.
assembled
Post by assembled »
I have [edit: read] a conspiracy theory that TD was made more petrol-like for better buyer acceptance by using such camshaft design though it seems counterintuitive...
BTW, would you happen to have measurements of your 1.1bar + 1.9NA cam?
I've heard the same theory too, but wouldn't have said the TD was particularly petrol like. I suppose compared to what other diesels were around in 1988, like the 2.3 litre Peugeot unit in the Sierra, it was! Although to be fair, that was replaced a year or so later with Ford's TD unit.
It's actually running slightly less than 1.1 bar now, but Kitch put it on his dyno last year and we got 114 bhp as a best of 4 runs, or just over 100 bhp at the wheels. Torque was 167 lb/ft at 2400 rpm (or for comparison purposes, 174 lb/ft using the DIN method as Citroen did when it was new) - interesting how the peak has moved higher up the rev range.
If you remember from that same session we put Timex on the rolling road and came to the tentative conclusion that it's got a TD cam fitted. This was because between 2 & 3k rpm the torque and power actually dropped off, which would coincide to the turbo kicking in on a 17TD engine. I've not yet fitted the replacement cam I have so we can't have another go to prove this, but it is one way to reduce the feeling of turbo lag.
Incidentally, the replacement cam isn't a standard one for the 19NA - The 19NA cam that I bought from Jaba will be going the 19TD engine for Fred, and I'll be pulling the 17NA cam out of Fred's old engine for Timex. This is because the 17NA cam has more duration than the 19, and I figured Timex needed all the help it could get power wise. It'll be interesting to see what it does.
assembled
Post by assembled »
Edit: following data is sourced from Haynes manual and does not agree to Citroen data provided later in this topic thus most likely incorrect!
Spoiler: show
According to Haynes manual, XUD7 (NA) has huge late overlap:
XUD7 (1.8 N/A)
Intake opens: 8° BTDC
Intake closes: 40° ABDC
lift height: ?? mm
Exhaust opens: 56° BBDC
Exhaust closes: 12° ATCD
lift height: ??
I do not have lift specs though. Huge overlap, very late exhaust opening and closing...
If my pictures are correct, 1.8 N/A also has pump pulley on the other end, right?
themildbunch
Post by themildbunch »
I too have a N/A cam but haven't fitted it yet in my TD...
Until recently my Lucas pumped TD estate was pretty standard and performance off boost was very, lacklustre.
Increasing the fuelling made a huge difference off boost, making the car much more drivable especially in our hilly area.
I've heard rumours these pumps were deliberately setup quite lean from new to differentiate the performance between the models more....
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
JayW
x 13
Post by JayW »
I fitted a 19 n/a cam to the TGDt and i couldn't tell ANY notable difference in any terms!
Yep, all BX diesel camshafts have the pulley at the other end to run the pump.
It'll be interesting to see what happens with Timex when I put a different cam in. At present, if I keep the revs low and change up as early as poss. it's phenomenally economic, and has loads of torque - up to 2k rpm the rolling road showed more power and torque than The Estate that's now in Tim's hands, and don't forget the square port head on Timex is supposed to mean a power loss of about 7bhp against the later oval port head. On the other hand you notice the power drop off between 2 & 3k, particularly in top, and have to run it quite hard up through the gears if you want to miss it. I'm hoping I can lose the power drop without losing too much low end grunt.
assembled
Post by assembled »
I am eager to see results of that. 1.7 NA cam should reduce low end torque due to overlap, late IVC, but increase high end performance. It might as well boost fuel economy when driven lightly. [Edit: just my uneducated opinion] Anyone would happen to have fuel economy specs of 1.7D, 1.7TD and 1.9D?
It may take a day or so to look them up but I'm sure I've go them somewhere.
IIRC the 1.9D square port engine (up to about 1987 or '88 in the BX) is supposed to do about 45mpg combined, while the later round port engine does a few mpg better then that. Mine's a hybrid of later block and internals, pump and injectors with early head and manifolds and I generally get about 48mpg with me driving it fairly hard up to the speed limit of whatever road I'm on, and slowing down as little as possible for roundabouts etc (after all, it takes so long to get the speed back!). One thing I have learned about official fuel specs when it comes to Citroens is that they rarely match real life.
assembled
Post by assembled »
Measurement standard is very outdated and is based on 1960s driving conditions (slow acceleration, deceleration, etc.)... What is important at this point, all models should have measurements done under same conditions and consequently have comparable results.
By the way, if someone could find power/torque curves of mentioned motors it would be tremendously informative in scope of this topic!
assembled
Post by assembled »
Some more research.
It seems that there are two interchangeable long camshafts: 0801 C9 from 1.8TD turbo and 0801 C2 from many other versions.
There also was a short camshaft 0801 E8 used in old 1.8D 161A/A9A motor with completely different timings and 0801 F7 used in 1.9SD motors. Not usable in 1.8TD, but mentioned here as I have their timings (see below).
Lift height Data from Citroen document:
unlit 09/86 161A/162
Intake 8,8 mm, exhaust 9,4 mm
from 09/86 161A/162 and A9A/D8A/D8B/D8C/D9A/D9B/D9D/DHX/DHY/DJY/DJZ/DHV/DHW
Intake 9,2 mm, exhaust 9,4 mm
AJZ/A8A/A8B (the 1.8TD engines)
Intake 8,4 mm, exhaust 8,8 mm
Timing information (French):
BX:
DIESEL FUEL AND 1,769L AND 1,905L EXCEPT PRESS PUMP 6+2 + NON-SINKING
0801 C2 ENGINE CAMSHAFT
DIESEL FUEL AND 1,769L AND TURBO
0801 C9 ENGINE CAMSHAFT LONG
DIESEL FUEL AND 1,905L AND PRESS PUMP 6+2 + NON-SINKING
0801 E8 ENGINE CAMSHAFT SHORT
C15:
XUD7 DIESEL UNTIL RPO 06264
0801 C2 ENGINE CAMSHAFT - UNTIL RPO 04773 LONG
0801 E8 - SINCE RPO 04774 UNTIL RPO 05169 SHORT
0801 C2 - SINCE RPO 05170 UNTIL RPO 05650 LONG
0801 C2 - POWER STEERING SINCE RPO 06171 LONG
0801 E8 - SINCE RPO 05651 SHORT
XUD7 DIESEL SINCE RPO 06265
0801 E8 ENGINE CAMSHAFT - EXCEPT POWER STEERING SHORT
0801 C2 - POWER STEERING LONG
Xantia I:
DIESEL XUD9 UNTIL RPO 06264 OR TURBO DIESEL XUD9TE UNTIL RPO 06264
Xantia II:
DIESEL TURBO XUD9SD SINCE RPO 06265 OR DIESEL XUD9 SINCE RPO 06265 OR TURBO DIESEL XUD9TE SINCE RPO 06265
0801 E8 ENGINE CAMSHAFT - DIESEL XUD9
0801 E8 ENGINE CAMSHAFT - TURBO DIESEL XUD9TE
0801 F7 - DIESEL TURBO XUD9SD
From above data we have different cams:
Short (not interesting...): 0801 E8. It is used in huuge list of cars:
Spoiler: show
Make Modle Engine CC KW cylinder Type Year
CITROEN C25 1.9 D 1905 51 4 Bus 1987-1994
CITROEN C15 1.8 D 1769 44 4 Box 1986-2000
CITROEN ZX 1.9 D 1905 47 4 Hatchback 1991-1997
CITROEN ZX 1.9 TD 1905 66 4 Hatchback 1992-1997
PEUGEOT 205 Mk II 1.7 Diesel 1769 44 4 Hatchback 1987-1998
PEUGEOT 205 1.7 Diesel 1769 44 4 Hatchback 1983-1987
PEUGEOT 309 1.9 D 1905 47 4 Hatchback 1986-1989
PEUGEOT 309 Mk II 1.9 Diesel 1905 47 4 Hatchback 1989-1993
PEUGEOT 405 1.8 Turbo Diesel 1769 66 4 Saloon 1988-1992
PEUGEOT 405 1.9 Diesel 1905 47 4 Saloon 1988-1992
PEUGEOT 405 1.9 Diesel 1905 51 4 Saloon 1988-1992
PEUGEOT 405 1.8 TD 1769 66 4 Estate 1988-1992
PEUGEOT 405 1.9 D 1905 47 4 Estate 1988-1992
PEUGEOT 405 1.9 D 1905 51 4 Estate 1988-1992
PEUGEOT J5 1.9 D 1905 51 4 Bus 1990-2014
PEUGEOT 306 1.9 DT 1905 66 4 Hatchback 1993-2001
PEUGEOT BOXER 1.9 TD 1905 66 4 Bus 1994-2002
PEUGEOT 306 1.9 D 1905 50 4 Hatchback 1994-2001
PEUGEOT 306 1.9 SRDT 1905 66 4 Saloon 1994-2001
PEUGEOT 306 1.9 SLD 1905 50 4 Saloon 1994-2001
PEUGEOT 405 Mk II 1.9 D 1905 50 4 Saloon 1994-1995
PEUGEOT 405 Mk II 1.9 D 1905 50 4 Estate 1994-1996
CITROEN XANTIA 1.9 Turbo D 1905 66 4 Hatchback 1994-1998
CITROEN ZX 1.9 D 1905 47 4 Estate 1993-1997
CITROEN ZX 1.9 TD 1905 66 4 Estate 1993-1997
CITROEN RELAY 1.9 TD 1905 68 4 Bus 1994-2002
CITROEN XANTIA 1.9 D 1905 50 4 Hatchback 1994-1998
CITROEN ZX 1.9 D 1905 50 4 Hatchback 1994-1997
CITROEN ZX 1.9 D 1905 50 4 Estate 1994-1997
CITROEN RELAY 1.9 TD 1905 66 4 Bus 1994-2002
PEUGEOT 806 1.9 TD 1905 66 4 MPV 1995-2002
FIAT ULYSSE 1.9 TD (220AH5) 1905 66 4 MPV 1995-2002
PEUGEOT 406 1.9 TD 1905 66 4 Saloon 1996-2004
CITROEN DISPATCH 1.9 TD 1905 68 4 MPV 1996-2014
CITROEN DISPATCH 1.9 D 1905 51 4 MPV 1995-1998
FIAT SCUDO Combinato 1.9 TD 1905 68 4 Estate 1996-2014
FIAT SCUDO Combinato 1.9 D 1905 51 4 Estate 1996-1998
PEUGEOT EXPERT 1.9 TD 1905 68 4 MPV 1996-2014
CITROEN BERLINGO I 1.8 D (MBA9A, MCA9A) 1769 43 4 Box 1996-2014
CITROEN BERLINGO I 1.9 D (MBDJY) 1905 51 4 Box 1996-2014
PEUGEOT 406 1.9 TD 1905 68 4 Saloon 1996-2004
CITROEN BERLINGO I 1.9 D (MFDJY) 1905 50 4 MPV 1996-2014
PEUGEOT 406 1.9 TD 1905 66 4 Estate 1996-2004
PEUGEOT BOXER Box 1.9 D 1905 51 4 Box 1994-2002
PEUGEOT RANCH 1.8 D 1769 43 4 Box 1996-2014
PEUGEOT RANCH 1.9 D 1905 51 4 Box 1996-2014
PEUGEOT RANCH 1.9 D 1905 50 4 MPV 1996-2014
PEUGEOT EXPERT 1.9 TD 1905 66 4 MPV 1996-2014
PEUGEOT EXPERT Van 1.9 D 1905 51 4 Box 1996-2014
PEUGEOT EXPERT 1.9 D 1905 51 4 Flatbed / Chassis 1996-2014
PEUGEOT EXPERT Van 1.9 TD 1905 66 4 Box 1996-2014
PEUGEOT EXPERT 1.9 TD 1905 66 4 Flatbed / Chassis 1996-2014
PEUGEOT EXPERT Van 1.9 TD 1905 68 4 Box 1996-2014
PEUGEOT EXPERT 1.9 TD 1905 68 4 Flatbed / Chassis 1996-2014
PEUGEOT J5 1.9 D 1905 51 4 Box 1990-2014
PEUGEOT J5 1.9 D 1905 51 4 Flatbed / Chassis 1990-2014
PEUGEOT BOXER 1.9 D 1905 51 4 Bus 1994-2002
PEUGEOT 306 Break 1.9 TD 1905 66 4 Estate 1997-2002
PEUGEOT 306 Break 1.9 D 1905 50 4 Estate 1997-2002
PEUGEOT 806 1.9 TD 1905 68 4 MPV 1997-2002
CITROEN XSARA 1.9 TD 1905 66 4 Hatchback 1997-2000
CITROEN XSARA 1.9 TD 1905 66 4 Estate 1997-2000
CITROEN RELAY 1.9 D 1905 51 4 Box 1994-2002
CITROEN RELAY 1.9 TD 1905 68 4 Box 1994-2002
CITROEN XANTIA 1.9 Turbo D 1905 66 4 Hatchback 1998-2003
PEUGEOT 206 1.9 D 1868 51 4 Hatchback 1998-2001
PEUGEOT 306 1.9 D 1905 55 4 Hatchback 1998-2001
PEUGEOT 306 1.9 D 1905 55 4 Saloon 1998-2001
PEUGEOT 306 Break 1.9 D 1905 55 4 Estate 1998-2002
CITROEN XSARA 1.9 D 1868 51 4 Hatchback 1998-2005
CITROEN XSARA 1.9 D 1868 51 4 Estate 1998-2005
CITROEN BERLINGO I 1.9 D (MFWJZ) 1868 51 4 MPV 1998-2014
FIAT SCUDO 1.9 TD 1905 68 4 Box 1998-2014
FIAT SCUDO 1.9 D 1905 51 4 Box 1996-2014
FIAT SCUDO Combinato 1.9 TD Eco 1905 66 4 Estate 1996-2014
FIAT DUCATO 1.9 TD 1905 66 4 Bus 1998-2002
PEUGEOT 306 1.9 D 1868 51 4 Hatchback 1998-2001
PEUGEOT 306 Break 1.9 D 1868 51 4 Estate 1998-2002
PEUGEOT 306 1.9 D 1868 51 4 Saloon 1998-2001
FIAT DUCATO 1.9 TD 1905 66 4 Box 1998-2002
FIAT SCUDO 1.9 TD 1905 66 4 Box 1996-2014
PEUGEOT 306 1.8 D 1769 43 4 Hatchback 1993-2001
PEUGEOT 309 Mk II 1.8 Diesel 1769 44 4 Hatchback 1989-1993
CITROEN DISPATCH 1.9 D 70 1868 51 4 MPV 1998-2014
CITROEN RELAY 1.9 D 1905 51 4 Bus 1999-2002
CITROEN ZX 1.8 D 1769 44 4 Estate 1993-1997
CITROEN ZX 1.8 D 1769 44 4 Hatchback 1993-1997
CITROEN RELAY 1.9 TD 1905 68 4 Flatbed / Chassis 1994-2002
CITROEN RELAY 1.9 TD 1905 66 4 Flatbed / Chassis 1994-2002
CITROEN RELAY 1.9 TD 1905 66 4 Box 1994-2002
PEUGEOT RANCH 1.9 D 1868 51 4 MPV 1998-2014
FIAT SCUDO Combinato 1.9 D 1868 51 4 Estate 1998-2014
CITROEN BERLINGO I 1.9 D 70 (MBWJZ, MCWJZ) 1868 51 4 Box 1999-2014
FIAT DUCATO 1.9 D 1905 50 4 Flatbed / Chassis 1998-2002
FIAT DUCATO 1.9 TD 1905 66 4 Flatbed / Chassis 1998-2002
TOYOTA COROLLA 1.9 D (WZE110_) 1867 51 4 Saloon 2000-2002
TOYOTA COROLLA Wagon 1.9 D (WZE110_) 1867 51 4 Estate 2000-2002
PEUGEOT BOXER Box 1.9 D 1905 50 4 Box 1999-2002
PEUGEOT BOXER Box 1.9 TD 1905 66 4 Box 1999-2002
PEUGEOT BOXER 1.9 TD 1905 66 4 Flatbed / Chassis 1998-2002
CITROEN BERLINGO I 1.8 D (MFA9A) 1769 43 4 MPV 1998-2014
CITROEN BERLINGO I 1.9 D 70 4WD (MBWJZ, MCWJZ) 1868 51 4 Box 1998-2014
CITROEN BERLINGO I 1.9 D 4WD (MFWJZ) 1868 51 4 MPV 1998-2014
CITROEN DISPATCH Van 1.9 D 70 1868 51 4 Box 1998-2014
CITROEN XSARA 1.9 TD 1905 66 4 Coupe 1998-2000
CITROEN XSARA 1.9 D 1868 51 4 Coupe 1999-2005
TOYOTA COROLLA 1.9 D (WZE110_) 1867 51 4 Hatchback 2000-2002
TOYOTA COROLLA Liftback 1.9 D (WZE110_) 1867 51 4 Hatchback 2000-2002
FIAT SCUDO 1.9 D 1868 51 4 Box 1998-2014
CITROEN C15 1.9 D 1868 44 4 Box 2000-2005
PEUGEOT EXPERT Van 1.9 D 70 1868 51 4 Box 1998-2014
PEUGEOT RANCH 1.9 D 4x4 1868 51 4 Box 2004-2014
PEUGEOT RANCH 1.9 D 1868 51 4 Box 1996-2014
PEUGEOT 205 Mk II 1.9 Diesel 1905 51 4 Hatchback 1987-1994
FIAT DUCATO 1.9 TD 1905 59 4 Box 1998-2001
PEUGEOT 405 1.8 GLD 1769 44 4 Estate 1990-1992
CITROEN C25 1.9 D 1400 1905 51 4 Box 1988-1994
CITROEN C25 1.9 D 4x4 1905 51 4 Box 1988-1994
CITROEN C25 1.9 1905 51 4 Flatbed / Chassis 1988-1994
PEUGEOT 306 Break 1.8 D 1769 44 4 Estate 1997-2000
PEUGEOT 405 1.8 D 4x4 1769 66 4 Saloon 1987-1992
CITROEN BERLINGO I 1.9 D (MFDJY) 1905 51 4 MPV 1996-1999
PEUGEOT RANCH 1.9 D 1905 51 4 MPV 1996-1998
PEUGEOT 405 1.8 DT 4x4 1769 66 4 Estate 1990-1992
CITROEN C25 1.9 DT 1929 60 4 Box 1991-1994
CITROEN DISPATCH Van 1.9 DT 1905 65 4 Box 1995-2000
PEUGEOT 306 1.9 D 1905 51 4 Hatchback 1993-1999
PEUGEOT 306 1.9 D 1905 69 4 Hatchback 1993-1997
PEUGEOT 306 1.8 D 1769 44 4 Saloon 1997-2000
PEUGEOT 306 1.9 STD 1905 51 4 Saloon 1994-1995
PEUGEOT EXPERT 1.9 D 1868 51 4 Flatbed / Chassis 1998-2003
PEUGEOT 306 Break 1.9 D 1905 51 4 Estate 1997-1999
FIAT DUCATO 1.9 TD 1905 59 4 Flatbed / Chassis 1998-2001
CITROEN C25 1.9 DT 1929 60 4 Flatbed / Chassis 1991-1994
PEUGEOT 205 Mk II 1.8 XDT 1769 58 4 Hatchback 1990-1997
PEUGEOT 405 Mk II 1.9 D 1905 51 4 Estate 1993-1995
CITROEN C15 1.8 D 1769 44 4 Estate 1987-2000
PEUGEOT J5 1.9 D 1905 51 4 Box 1987-1990
PEUGEOT J5 1.9 D 1905 51 4 Flatbed / Chassis 1987-1990
Another short one 0801 F7, used in Xsara, Xantia 1.9SD, engines DHV, DHW:
Spoiler: show
CITROEN XANTIA 1.9 SD 1905 55 4 Hatchback 1996-1998
CITROEN XANTIA 1.9 SD 1905 55 4 Estate 1997-1998
CITROEN XANTIA 1.9 SD 1905 55 4 Estate 1998-2003
CITROEN XANTIA 1.9 SD 1905 55 4 Hatchback 1998-2003
CITROEN XSARA 1.9 SD 1905 55 4 Hatchback 1998-2000
CITROEN XSARA 1.9 D 1905 55 4 Estate 1998-2000
Long:
0801 C2
Used in:
Spoiler: show
Long
0801 C9
Spoiler: show
CITROEN BX TRD Turbo 1769 66 4 Hatchback 1988-1993
CITROEN BX Break TRD Turbo 1769 66 4 Estate 1988-1994
PEUGEOT 205 Mk II 1.7 TD 1769 57 4 Hatchback 1990-1998
PEUGEOT 309 Mk II 1.8 TD 1769 57 4 Hatchback 1989-1993
Final compatibility conclusion:
1.7TD motor can be equipped with originally mounted 0801 C9 with narrower lobes and smaller lift or a wider/higher camshaft 0801 C2.
If there are any mistakes in my information, please do not hesitate and say so.
