TZD Turbo 1.8TD XUD7TE camshaft options
- My Cars: 1991 Citroen BX TZD Turbo
1989 Citroen BX GTi 4x4 - x 2
Hello, I am overhauling my TZD Turbo and have come up to choosing a better camshaft.
Options with high pressure pump drive on the other end I have:
XUD7TE original
Intake opens: 4°30' BTDC
Intake closes: 20°30' ABDC
lift height: 8.25 mm
Exhaust opens: 39°15' BBDC
Exhaust closes: 3°45' BTCD
lift height: 8.5mm
one from XUD9A (1.9 N/A diesel):
Intake opens: 4° BTDC
Intake closes: 45° ABDC
lift height: 9.2 mm
Exhaust opens: 43° BBDC
Exhaust closes: 0° BTCD
lift height: 9.4 mm
There are some rumors about later being an upgrade performance-vise. It should retain low-end torque and increase high-end one.
There are differences in valve overlap, N/A cam has much longer opening times and greater lift height. This should allow more air in to the cylinder, right?
I have found that there are no differences in geometry of XUD7TE and XUD9 regarding pistons and valves: in both engines valve recess and piston protrusion is the same (please do not hessitate to correct me if I am wrong) so different timings and lift height should not result in piston cathing a valve.
I indend increasing turbo boost to some safe value (to be defined) and putting some more fuel.
Thank you for your input in advance!
XUD7TE original
lift height: 8.5mm
lift height: 9.2 mm
lift height: 9.4 mm
1992 TZD Turbo berline, aircon, ABS
1991 TZD Turbo berline
1989 GTi 4x4 berline, ABS
- Tim Leech
- x 148
Re: TZD Turbo 1.8TD XUD7TE camshaft options
Ive heard that fitting a 1.9D cam give better pick up.
- x 88
N/A cam will give more grunt, purely because the valves open more, and for longer. There must be a downside to the N/A cam (otherwise PSA would have fitted it to all the XUDTs), but I've yet to work it out
Only downside on a petrol with longer duration and lift is you start getting a lumpy idle and a reduction in vacuum pressure for things like the servo, or mechanical fuel injection if you have it. Diesels have vacuum pumps for that kind of thing, and they combust differently anyway. Hopefully we'll have a definitive answer by the end of this one!
1990(H) 16Valve (Rouge Furio)
- mat_fenwick
- x 19
I'm running a 1.9D NA cam in my 1.9TD engine, but I can't give a back to back verdict as I changed the cam at the same time I swapped the engine. It certainly ran well enough on standard boost, and even better at 1.1 bar
The earlier square port head had a cam with greater lift/duration from memory, and that head was fitted to Peugeot 205s and 309s right through production. So finding one of those with PAS would give you the provision to drive the hydarulic pump.
I can only think PSA used a softer cam on the TDs for reasons of efficiency - they already had a class-leading diesel in terms of performance so no need to increase that. Or perhaps they were being conservative in terms of engine longevity - I've wondered if that's why they initially used the smaller bore (ie. thicker/stronger cylinder walls) engine when they first developed the TD. Moving onto the 1.9 when real-world experience showed the smaller engine was durable enough.
I have [edit: read] a conspiracy theory that TD was made more petrol-like for better buyer acceptance by using such camshaft design though it seems counterintuitive...
BTW, would you happen to have measurements of your 1.1bar + 1.9NA cam?
- mat_fenwick
- x 19
I've heard the same theory too, but wouldn't have said the TD was particularly petrol like. I suppose compared to what other diesels were around in 1988, like the 2.3 litre Peugeot unit in the Sierra, it was! Although to be fair, that was replaced a year or so later with Ford's TD unit.
It's actually running slightly less than 1.1 bar now, but Kitch put it on his dyno last year and we got 114 bhp as a best of 4 runs, or just over 100 bhp at the wheels. Torque was 167 lb/ft at 2400 rpm (or for comparison purposes, 174 lb/ft using the DIN method as Citroen did when it was new) - interesting how the peak has moved higher up the rev range.
- citsncycles
If you remember from that same session we put Timex on the rolling road and came to the tentative conclusion that it's got a TD cam fitted. This was because between 2 & 3k rpm the torque and power actually dropped off, which would coincide to the turbo kicking in on a 17TD engine. I've not yet fitted the replacement cam I have so we can't have another go to prove this, but it is one way to reduce the feeling of turbo lag.
Incidentally, the replacement cam isn't a standard one for the 19NA - The 19NA cam that I bought from Jaba will be going the 19TD engine for Fred, and I'll be pulling the 17NA cam out of Fred's old engine for Timex. This is because the 17NA cam has more duration than the 19, and I figured Timex needed all the help it could get power wise. It'll be interesting to see what it does.
Edit: following data is sourced from Haynes manual and does not agree to Citroen data provided later in this topic thus most likely incorrect!
Spoiler: show
- themildbunch
I too have a N/A cam but haven't fitted it yet in my TD...
Until recently my Lucas pumped TD estate was pretty standard and performance off boost was very, lacklustre.
Increasing the fuelling made a huge difference off boost, making the car much more drivable especially in our hilly area.
I've heard rumours these pumps were deliberately setup quite lean from new to differentiate the performance between the models more....
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
- JayW
- x 13
I fitted a 19 n/a cam to the TGDt and i couldn't tell ANY notable difference in any terms!
- citsncycles
Yep, all BX diesel camshafts have the pulley at the other end to run the pump.I do not have lift specs though. Huge overlap, very late exhaust opening and closing...
If my pictures are correct, 1.8 N/A also has pump pulley on the other end, right?
It'll be interesting to see what happens with Timex when I put a different cam in. At present, if I keep the revs low and change up as early as poss. it's phenomenally economic, and has loads of torque - up to 2k rpm the rolling road showed more power and torque than The Estate that's now in Tim's hands, and don't forget the square port head on Timex is supposed to mean a power loss of about 7bhp against the later oval port head. On the other hand you notice the power drop off between 2 & 3k, particularly in top, and have to run it quite hard up through the gears if you want to miss it. I'm hoping I can lose the power drop without losing too much low end grunt.I fitted a 19 n/a cam to the TGDt and i couldn't tell ANY notable difference in any terms!
I am eager to see results of that. 1.7 NA cam should reduce low end torque due to overlap, late IVC, but increase high end performance. It might as well boost fuel economy when driven lightly. [Edit: just my uneducated opinion] Anyone would happen to have fuel economy specs of 1.7D, 1.7TD and 1.9D?
- citsncycles
It may take a day or so to look them up but I'm sure I've go them somewhere.
IIRC the 1.9D square port engine (up to about 1987 or '88 in the BX) is supposed to do about 45mpg combined, while the later round port engine does a few mpg better then that. Mine's a hybrid of later block and internals, pump and injectors with early head and manifolds and I generally get about 48mpg with me driving it fairly hard up to the speed limit of whatever road I'm on, and slowing down as little as possible for roundabouts etc (after all, it takes so long to get the speed back!). One thing I have learned about official fuel specs when it comes to Citroens is that they rarely match real life.
Measurement standard is very outdated and is based on 1960s driving conditions (slow acceleration, deceleration, etc.)... What is important at this point, all models should have measurements done under same conditions and consequently have comparable results.
By the way, if someone could find power/torque curves of mentioned motors it would be tremendously informative in scope of this topic!
Some more research.
It seems that there are two interchangeable long camshafts: 0801 C9 from 1.8TD turbo and 0801 C2 from many other versions.
There also was a short camshaft 0801 E8 used in old 1.8D 161A/A9A motor with completely different timings and 0801 F7 used in 1.9SD motors. Not usable in 1.8TD, but mentioned here as I have their timings (see below).
Lift height Data from Citroen document:
unlit 09/86 161A/162
Intake 8,8 mm, exhaust 9,4 mm
from 09/86 161A/162 and A9A/D8A/D8B/D8C/D9A/D9B/D9D/DHX/DHY/DJY/DJZ/DHV/DHW
Intake 9,2 mm, exhaust 9,4 mm
AJZ/A8A/A8B (the 1.8TD engines)
Intake 8,4 mm, exhaust 8,8 mm
Timing information (French):
BX:
DIESEL FUEL AND 1,769L AND 1,905L EXCEPT PRESS PUMP 6+2 + NON-SINKING
0801 C2 ENGINE CAMSHAFT
DIESEL FUEL AND 1,769L AND TURBO
0801 C9 ENGINE CAMSHAFT LONG
DIESEL FUEL AND 1,905L AND PRESS PUMP 6+2 + NON-SINKING
0801 E8 ENGINE CAMSHAFT SHORT
C15:
XUD7 DIESEL UNTIL RPO 06264
0801 C2 ENGINE CAMSHAFT - UNTIL RPO 04773 LONG
0801 E8 - SINCE RPO 04774 UNTIL RPO 05169 SHORT
0801 C2 - SINCE RPO 05170 UNTIL RPO 05650 LONG
0801 C2 - POWER STEERING SINCE RPO 06171 LONG
0801 E8 - SINCE RPO 05651 SHORT
XUD7 DIESEL SINCE RPO 06265
0801 E8 ENGINE CAMSHAFT - EXCEPT POWER STEERING SHORT
0801 C2 - POWER STEERING LONG
Xantia I:
DIESEL XUD9 UNTIL RPO 06264 OR TURBO DIESEL XUD9TE UNTIL RPO 06264
Xantia II:
DIESEL TURBO XUD9SD SINCE RPO 06265 OR DIESEL XUD9 SINCE RPO 06265 OR TURBO DIESEL XUD9TE SINCE RPO 06265
0801 E8 ENGINE CAMSHAFT - DIESEL XUD9
0801 E8 ENGINE CAMSHAFT - TURBO DIESEL XUD9TE
0801 F7 - DIESEL TURBO XUD9SD
From above data we have different cams:
Short (not interesting...): 0801 E8. It is used in huuge list of cars:
Another short one 0801 F7, used in Xsara, Xantia 1.9SD, engines DHV, DHW:
Long:
0801 C2 Used in:
Long
0801 C9:
Final compatibility conclusion:
1.7TD motor can be equipped with originally mounted 0801 C9 with narrower lobes and smaller lift or a wider/higher camshaft 0801 C2.
If there are any mistakes in my information, please do not hesitate and say so.
BX:
C15:
Xantia I:
Xantia II:
Spoiler: show
Spoiler: show
0801 C2 Used in:
Spoiler: show
0801 C9:
Spoiler: show
