tailgate badge removel
greendale65
x 20
Post by greendale65 »
Hi all. Anyone ever removed these let me know
how .
Alan :) :)
Re: tailgate badge removel
Post by Mothman »
Use a hair dryer on hotest setting and it will come off easily.
Then you will need the special sticky tape to put it back on, readily available on ebay.
If a hair-dryer still doesn't make the glue soft enough to lift of the badge (without melting your paint!), run a piece of fishing line behind the badge and slice it off - that always works.
greendale65
x 20
Paul296 wrote:If a hair-dryer still doesn't make the glue soft enough to lift of the badge (without melting your paint!), run a piece of fishing line behind the badge and slice it off - that always works.
Nice one something for me to do.
Only I've got a nice one in the shed
its Chrome with a chevron
on it.
electrokid
Post by electrokid »
If none of that works you might try molybdenum wire - wrap it around tools NOT your finger - it'll have your finger off.
http://www.ebay.co.uk/itm/0-11mm-Molybd ... 3a965691f3
