And a Birotor…
hilarystone
My Cars: Citroen BX 16V x 2, BX Van 16V, Visa GTI, CX Ambulance Turbo diesel, C8, Xsara VTS, Xantia Activa, Lotus Elan 1970, Clan Crusader
And a Birotor…
Post by hilarystone »
Some of you may have spotted clues about me looking at a GS Birotor in France a little while ago – involving one day of 650 miles in the BX Sport and second day of 550 miles. After giving it a look over I realised the structure looked pretty sound I decided that this car was going to be the only way I'd ever manage to afford a Birotor. Wankel engines are not too expensive to rebuild – they have a relatively small number of parts and Mazda have solved the seal problems that plagued the early rotary engines. I managed to agree a deal with the French seller despite him having no English and me have a tiny amount of French…
Well last week I went over and collected it on a trailer behind the C8. Two sets of ramps were needed to get it onto the trailer – the seller had never had the engine running so the suspension was completely down. But we were away within an hour and a half including completing the paperwork. It came with a Carte Grise – which is needed in order to get it registered here but in France you need a CT (the French equivalent of MOT) in order to get the Carte Grise – he'd managed to get a CT for this car!
The Birotor has a Wankel engine almost identical to the NSU RO80, bodywork mostly similar to a GS but with slightly wider front and rear wings, a different front end underneath – the Wankel motor is arranged transversely with C-Matic gearbox a la Cx and the brakes are suspension are supposedly pretty much CX like. The rear brakes are apparently SM.
I took it over to the Westons today and first job is to get the engine and gearbox out so that a rotary engine specialist can go through the engine. The plans are to strip the engine bay out – it needs repainting as does most of the car. There's some welding to the front end of the nearside sill to be done and probably other places too. Tyres will need to be sourced too…
Hilary Stone
http://www.Hilarystone.com
1985 Citroen CX Ambulance, 2 x 1989 Citroen BX 16V, 1996 Citroen Xantia Activa, 1990 Citroen BX GTI 4x4, 1987 Citroen Visa GTI, 2004 Citroen C8 2.2hdi, Citroen BX Van 16V, Clan Crusader, 1970 Lotus Elan, Citroen Xsara VTS phase 2
sdelasal
Re: And a Birotor…
Post by sdelasal »
That sounds a very interesting car Hilary - look forward to seeing it, in the flesh, in the future.
bx petrol auto saloon
Re: And a Birotor…
That does look in incredibly very good nick indeed =D> 8)
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
x 6
Re: And a Birotor…
Post by Tinkley »
Surprised with the 'MOT' you did not drive it back..... :lol:
Re: And a Birotor…
Amazing Hilary - well done! =D> The Birotor isn't just a car; it's a legend. :)
x 15
Re: And a Birotor…
I'm even more jealous of your fleet now! What's the plan for it - regular use like the rest of your collection?
Re: And a Birotor…
Post by Mothman »
Wow, what a great motor, and a very rare beast too. I do hope you can get it running again without the problems they were plagued with. Good luck with it, a great find.
Re: And a Birotor…
Awesome motor, what size is the engine & how much power do these rotary beasts give out?
Re: And a Birotor…
Huge respect and envy ;)
benifotrem1
Re: And a Birotor…
Post by benifotrem1 »
Love theses cars and rare as rocking horse manure.
Enjoy your new car
Benifotrem1
1985 BX19 GT
1970 SEAT 124 ESTATE (same as FIAT)
1971 HONDA PC50
MODERN CARS:
2005 AUDI ALLROAD 4.2
2000 SKODA FABIA 1.9 TDI ELEGANCE
hilarystone
Re: And a Birotor…
The plan for it is get the engine rebuilt first and then rebuild as and where necessary – certainly with the engine out it makes sense to remove the rest of the parts in the engine bay and repaint it. It needs a screen but that is standard GS I think… And will need work on the seat and interior. And then drive it regularly, Wankel engines with modern rotor tips are pretty reliable.
The two chamber rotary engine is rated at 107 bhp so will make a pretty rapid GS…
Hilary Stone
x 6
Re: And a Birotor…
Post by Tinkley »
Both Mazda and Norton did independent research on rotor tips for Wankel engines and both ended up with the same conclusion as far as I am aware. Cast iron was the best material. BTW the Norton research showed that there is a rev limit point somewhere (engine specific) where tip wear becomes a major issue. In their case I believe around 12k revs, the racer went to 18k and had to have the sealing blades replaced very regularly.
Still I can't foresee an R80 DKW unit getting quite in that realm. Pretty weird things to drive those Wankels as the torque curve is pretty much parallel to the power curve. I've been in a couple of RX Mazdas and the smoothness of the engine is incredible. No serious engine braking either, but not a real problem, Citroens are not short in that department, more like a 2 stroke bike.
1985 CITROEN BX 19GT C1TBX
x 107
Re: And a Birotor…
A right Q car! well done.
1963 VW BEETLE 1200
1985 BX 19GT Mk1
1985 BX 19 DTR Mk1
1991 BX 19TZI Auto A/C
1994 Xantia 1.8i SX
1972 Morris Marina 1.8 SDL
1979 Rover SD1 V8-S
1980 Morris Marina 1.7 HL
2003 Rover 25 1.6i XL 5 DR
Slagtrooper
Re: And a Birotor…
Post by Slagtrooper »
She's almost intact!
Congratulations, following this topic!
Citroën BX GTi 1993
. XU9JAZ engine, ZF 4HP14 Automatic gearbox
. Leather Seats, Air Conditioner, electric mirrors, windows and sunroof
. "16V type" Speedline Rims, "Ducktail" spoiler and rear vents
ORGA 5219 (February 22, 1991) - Made in Uruguay
Hot steamy night alone, I wait for you ♫ Cold brittle morning alone and I cry for you ♪ And when you finally call ♫ You cloak your moves in the shadows ♪♫♪
Re: And a Birotor…
Nice looking car. Not sure about a spare screen (I'll check) but I have some spare glass and possibly some better bumper trims etc. if you decide to change them.
