but have to say I'm also impressed by everyone's efforts in heavy loads too..B-Hive wrote:guess I was going the volume of the cargo rather than the weight..
One of the least spoken of merits when discussing the hydro suspension
mat_fenwick wrote:Yes, it's a 2050...fairly old but I rebuilt the engine a couple of years back.
Sadly stolen last Christmas
OK revise those tiles back. call it 2.5 tons and a full out load at 3 tons. Sounds more likely as the car will pull this on a trailer OK but if you ask it to support the load without extra wheels I can see it struggling. I believe towing weight as about 1 ton. Little as the car is light. The Trooper is something like 31/2 tons.rutter123 wrote:Was actually 440 bricks approx 750 kg
Only lightweight ones.... rather depends on the type, as the SD/SG varies a lot. My local brickworks ones are quite heavy at the 2.4 end of the scale and then the metric/imperial games begin..rutter123 wrote:Was actually 440 bricks approx 750 kg
I don't have that excuse, but I've somehow managed to acquire/accumulate six chainsaws (did have a couple more but I've, ahem, cut down recently) including the Jonsered, two old Danarm beasts from the sixties and a 1970s Pioneer I found in a skip earlier this year. I got two big Jonsered brushcutters (one with a blade, one with a line) for 30 quid each from the same auction as the chainsaw, a smaller Husqvarna one swapped for an old Apple Mac and a little McCulloch again found in a skip. No one seems to have put one of those pole saws into any of my local skips lately though - I'll have to keep my eye out!Mothman wrote:I have a load of saws and garden equipment on a commercial scale but not really needed so much having recently retired as a gardener.
I'll be sure to keep your sentiment in mind.Mothman wrote:So?
