Sucking noise.
Sucking noise.
When cruising the car is fine however when you boot it between 2500 and 4000 revs there is a noticeable sucking noise. Is it something to do with the turbo? I have only noticed it recently and I am sure it didn't do it a couple of weeks back.
- Vanny
BX 16v Ph2 - XPO - x 79
Re: Sucking noise.
Do you have Air Con?
A low refrigerant charge will do that.
Re: Sucking noise.
No Aircon. If I'm hot I have to do the usual and roll the window down!
- x 4
Re: Sucking noise.
Hose come off the intercooler? Or split?
Re: Sucking noise.
Easy to replace?
- x 4
Re: Sucking noise.
Sorry for the delay - yes, if it's just the hose come off or split, it's easy enough - very easy depending on exactly which one it was. I had the same thing recently after I'd had the intercooler off for cleaning and had forgotten to tighten one of the jubilee clips holding the plastic trunking onto the hose which actually goes to the turbo (the one that sits to the left of the intercooler as you look at the engine from the front). 10 second job to refit and tighten it up.
Re: Sucking noise.
Cheers bud, will have a look when I get back this weekend.
