Sucking noise.
burraston2006
Sucking noise.
When cruising the car is fine however when you boot it between 2500 and 4000 revs there is a noticeable sucking noise. Is it something to do with the turbo? I have only noticed it recently and I am sure it didn't do it a couple of weeks back.
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Re: Sucking noise.
Do you have Air Con?
A low refrigerant charge will do that.
burraston2006
Re: Sucking noise.
No Aircon. If I'm hot I have to do the usual and roll the window down!
KevR
Re: Sucking noise.
Hose come off the intercooler? Or split?
burraston2006
Re: Sucking noise.
Easy to replace?
KevR
Re: Sucking noise.
Sorry for the delay - yes, if it's just the hose come off or split, it's easy enough - very easy depending on exactly which one it was. I had the same thing recently after I'd had the intercooler off for cleaning and had forgotten to tighten one of the jubilee clips holding the plastic trunking onto the hose which actually goes to the turbo (the one that sits to the left of the intercooler as you look at the engine from the front). 10 second job to refit and tighten it up.
burraston2006
Re: Sucking noise.
Cheers bud, will have a look when I get back this weekend.
