Wtd Radiator cowling/fans for 16V Break Spare wheel carrier
hilarystone
My Cars: Citroen BX 16V, BX Van 16V, Visa GTI, CX Ambulance Turbo diesel, Xsara VTS Phase 1 and 2, Lotus Elan 1970, Clan Crusader, C8 2l petrol, 1982 GSA Pallas, 1974 GS Birotor
Post by hilarystone »
I am looking for the radiator cowling plus fans in order to finish off the 16V van… The cowling and fixing parts for the rad are the most important parts. And a Break spare wheel carrier…
Let us know if you have anything…
Many thanks
Hilary Stone
http://www.Hilarystone.com
Re: Wtd Radiator cowling/fans for 16V Break Spare wheel carr
Post by Mothman »
I do have a spare wheel carrier for an Estate but its pretty pitted and rusty. Could do piccies if you are interested?
hilarystone
Yes please…
Hilary Stone
Post by Mothman »
Okey dokey bud, ile pms some to you tmorra!!
x 83
I probably have both of your requirements on my TD estate. I am assuming that twin radiator fittings are the same for all models.
I am a way for a couple of weeks soon.
x 82
Jana, there are three types of twin fan setup that I know of. After sales with two single fans side by side, two even sized fans in a single housing, and two un even sized fans in a single housing. I've had two valvers with the latter type.
Are you after a particular type Hilary, or is function more important than form?
hilarystone
Function is more important than type – I need a the complete radiator cowling with fastenings etc
Thanks
Hilary Stone
x 82
How's this one for you?
hilarystone
Yes please that looks good – do you also have the plastic top pieces from the slam panel?
Hilary Stone
x 82
I think so, will have a look and let you know
Post by citronut »
Vanny wrote:Image
but theres only one fan in that housing :roll: #-o :wink:
hilarystone
That's how 16v come set up – you can add a second fan for towing etc…
Hilary Stone
Post by citronut »
i always thought the the likes of the GTI/16V and TD's all came with twin fans
x 82
I don't think any UK BX came with a twin fan unless it was an AC car, or specified with one at build. Though I'm sure someone will correct me very shortly.
I guess the argument for Citroen is, why include an expensive extra fan when you can have the customer pay you extra for it?
They don't really need a second fan unless your radiator is blocked by a condenser or your spending long durations under heavy load such as 20 minutes up hill or towing. It's much cheaper to specify the correct radiator size for 'normal' running, and don't forget that an electric cooling fan is typically useless over 40mph.
Post by Mothman »
My TZD has 2 fans, no a/c though. My mate Tim's TXD also had 2 fans, again no a/c. My TXD only has 1 fan so i dont think there is rhyme nor reason to it.
