8v GTi - Has started Smokin'
Hi all, I started driving the GTi again last month and it's great to be back in it. Only problem is that it recently started smoking when the engine has heated up. I am thinking that it is the stem seals and/or piston rings. I'm planning to bring it to my local garage towards the end of the month and get it checked out but I know that the replacement seals and rings from them would be mad money. Do you have any recommended products I could get them to order, if needed, ie. Replacement stem seals and piston rings? Thanks!
Sent from my iPad using Tapatalk
- x 148
Re: 8v GTi - Has started Smokin'
Its normally the valve stem seals....rare that the bottom end is an issue.
- Philip Chidlow
- x 25
/\ yep...
The problem with supplying parts yourself is what happens if they don't cure the problem? The garage could well put the blame on the bits you supply, and they may not offer a warranty. Worth speaking to them beforehand to see what they think.
The stem seals can technically be done with only the rocker cover off, not that I've ever done one this way. But maybe worth checking the techs can do this as it would save disturbing the head and the extra cost. If you have to remove head, then gasket/bolts/other seals like exhaust collar etc would all need replacing.
Thanks for the replies, folks. I'll see what the garage says and take it from there. I was asking for parts recommendations as one of the mechanics mentioned that seals cost €55 each!
I would certainly get a second opinion!
I'd reckon on £30 to £50 to a complete head gasket set, including all seals.
(Very quick search:) http://www.ebay.co.uk/itm/PEUGEOT-205-G ... 5b058e5645
It may be that the garage doesn't want the job, so they're pricing it as such that you don't go ahead with it. Maybe they're reluctant to have an older car in pieces and potentially taking up a bay for a while, if they think they may struggle to get bits part-way through the job?
hi all , you can change oil valve stem oil seals in place, but you do have to remove the cam shaft, i used to change a lot of these in the eights & nineties , to do the job in place you will need to remove the spark plugs and put compressed air down the plug hole, to hold up the valves, then you need a bar bolted to the back of the head to hook on to , to use as a leaver point to push down on the valve spring, to remove the valve colets. then you carefully pull of the old valve seal. fit new valve seal ,& in the old Haynes manual saying fit in reverser order.hope this helps, barry, ps i will try & post some pics of the tool i use.
I once watched someone do valve stem seals by pushing nylon rope into the spark plug hole to fill the gap and hold the valves up. Ingenious, not tried this approach myself but sure it worked ok.
I would surmise that if you did use either compressed air or pack with rope each cylinder would be at TDC so the valves can't drop far IF they were to fall down. So make sure of your cam timing marks.....
the first and simplest thing to check and make sure is in good order and doing its job fully, would be the crank case breather system, as this gets a build up of carbon in any/all the rolled up wire gauze,
if you car has both of these fitted, one will be in the oil filler cap, the other which most people forget or dont even know exists, is in the filler neck, and in between the two parts of the of the filler neck ( yes i said the two parts ),
as the center can be pushed up and out of the top end, this will reveal a roll of gauce which you can remove the tin tack, unroll, clean and reassemble,
the other causes of breather blockage are the rubber filler neck collapsed/folding over on its self, or build up of goooo in any of the breather circuit,
yes this used to be a common practice in those days, we had a modified spark plug which we broke out all its innards, and welded and airline adapter to it,CitroenBaz wrote:hi all , you can change oil valve stem oil seals in place, but you do have to remove the cam shaft, i used to change a lot of these in the eights & nineties , to do the job in place you will need to remove the spark plugs and put compressed air down the plug hole, to hold up the valves, then you need a bar bolted to the back of the head to hook on to , to use as a leaver point to push down on the valve spring, to remove the valve colets. then you carefully pull of the old valve seal. fit new valve seal ,& in the old Haynes manual saying fit in reverser order.hope this helps, barry, ps i will try & post some pics of the tool i use.
for the valve spring compressing you could lift the cam and followers away, then fit the cam back in place to use with a suitable home made tool, which could leaver against the cam shaft
Thanks again for the comments. I'm at a bit of a loss, though; no tools, shed, time and most importantly, no mechanical skills! This would mean having a garage do it and the costs would be too high. I'll keep driving it as it's the only car I have on the road at the moment. Its test is booked for the end of the month so I'll just put it through and see what they pick up.
I bought another car over the weekend and I'd like to see the GTi go to someone who can give it the TLC it needs. Is there anyone in Ireland interested in it, I wonder? It was registered in the UK and lived in Northern Ireland as well, so there shouldn't be any import/registration tax, if one was to bring it back to the UK. I dropped the price to €1300 but can talk on this, if needed. Thanks, Enda.
