Headlamp bulbs upgrade
jamescarruthers
Re: Headlamp bulbs upgrade
Post by jamescarruthers »
Kaapelimies wrote:Anyone of you tried to get more voltage to the bulb? I've installed this set (cost 17 Euros) to all my BX and Visas:
It's got 2 relays and all the wires and connectors ready to fit any H4 equipped car, fitting takes 5 minutes. It gave some 2 volts more to the bulb (voltage taken directly from alternator instead of battery), and there is a big difference! The biggest is, that now any "superbright" bulb like nightbreaker will break in two months... :lol: . But instead, you get a lot more light with normal H4 bulb (dont' use the cheapest as they will break because of the voltage). And this allows you to use 100W bulbs also without frying the original light switch!
Can you tell us where you got this from? I always fancied doing Matt's upgrade but have been too lazy to make a loom up; this I could possibly be bothered to do!
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Kaapelimies
x 16
Post by Kaapelimies »
They're available at Biltema, that's a swedish shop for car&household stuff. I think they don't send abroad, they do have shops in Finland, Sweden, Denmark and Norway. http://en.wikipedia.org/wiki/Biltema
x 87
A quick google for 'H4 wiring harness' brings up a whole load of outlets for a harness like this in the UK, such as this £12.99 offering from eBay
http://www.ebay.co.uk/itm/Auto-Car-H4-T ... 0567437129
jamescarruthers
Nice one, thank you both
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
x 137
For once i give Halfords some credit, i purchased 2 extreme brilliance +90% more light 472EB 55/60w ( BOGOF ) £15.99 a pair, much improved much better vision, a whiter and much brighter light, not sure its 90% more light but nonetheless a good result.
Halfords have on occasion made some decent bulbs, i've got some +50 one's that i bought 8 years ago, still work fine, not quite as good as osram nightbreakers, but that model is much newer.
jamescarruthers
Just installed the upragde loom as recommended earlier... absolutely fantastic!
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
x 20
rutter123 wrote:not sure its 90% more light but nonetheless a good result.
That's to do with the way the human eye perceives brightness - it needs to be around double the output to be seen as a significant improvement.
jamescarruthers
Just to add to the loom topic, I got the set that can handle the higher wattage bulbs (the "off-road" ones). It seemed sensible for just a few quid more.
http://pages.ebay.com/link/?nav=item.vi ... 0567437129
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
